Raythemond
Hi everybody, while travelling I experienced a major coolant leak and loss of the majority of my coolant . Thankfully I was close enough to a truck stop that I was able to coast into their lot just in time. Engine seems ok.
One of the diesel techs took pity on me and helped me. We found that one of the smaller coolant hoses had somehow (maybe I ran over something?) migrated into the cooling fan and had been gashed. In attempting to remove this hose at the bottom end we broke the male fitting that the hose mates with clean off. The component it was attached to appears to be a filter housing. It is maybe 5" square and it's directly below the oil filter.
Our "solution" was to bypass it by connecting the hose that flowed into that housing straight to the (I think) water pump. Basically we just deleted the water filter.
Filled it up with tap water (I know...) and brought it up to tempt, topped it off, and she ran great all the way home (150 miles). The tech obviously knows his stuff, but he's not a VW TDI guy. So I want to know what you guys and gals think. I won't have an opportunity to work on it for a week. Will it be o to drive as is till then? I'd rather not put high dollar vw coolant in it now just to have to buy anther round when I fix it.
Whatcha think? Thanks in advance!
