eddieleephd
I am reading up on the codes and fixes, however, I have a question.
The 0102 code is the main one and comes back within seconds, 0101 has only come on once so far.
Is it possible for an EGR to cause the 0102 (signal too low) and 0101 (signal implausible) codes?
I cleaned the intake when I replaced the turbo and there is a bit of spray from the EGR on the valve cover.
Is this something that could, for some reason, be caused by the new VNT17. Seems unlikely because the it has been in for a while without throwing a CEL.
I pulled the MAF and cleaned it and also did a quick check of the wires (visual and feel). I don't think wires are the issue.
I will probably pull the battery and clean the ground in the morning or afternoon tomorrow. I'll also throw the other MAF (Questionable) in my tool bag in case I have an issue while driving on my trip.
This is the first CEL since I got the car that was not caused by me leaving something unplugged.
