Andyinchville1
HI all,
Not sure where to put this because I want Economy AND power so I put my question here in the general section...
I am about to send in a newly acquired set of Bosch .205 injectors / nozzles
to get them gone through (cleaned / pop tested etc...).
I have read where I can get power AND economy by going with a bigger nozzle size BUT i wanted to do it once and get it done right in case I haven't read everything or maybe I misunderstood something.
Currently my car is in good mechanical shape but is stock (engine wise) with the exception of a Malone stage 1 tune with dynamic EGR.
I am on the quest for the best possible MPGs and the side affect is power to boot....my understanding is that the bigger the tune and the bigger the nozzle is the better my MPGs will be (unless of course if I USE the power....I plan on driving easy so I am not overly concerned about the clutch...I am the only driver of the car).
With that logic I figure on getting at least a Malone stage 2 (or should I go for 3 since the theory was bigger tune is more MPGs provided I stay off the power) and get the DLC 1019 nozzles put on after the injectors are tested / rebuilt.
Anybody have any experience with this and / or any other recommendations before I commit to getting it done?
Would a VAG com tool be needed / helpful with what I'm doing (I did read about adjusting IQ and all that but does the tune handle that or is that a separate issue?).
Thanks in advance for any and all help on this.
Andrew
Andrew
