tacolifestyle
2003 Jetta Wagon ALH, 5 Spd, 275,000 miles
Head Rebuilt around 225,000 miles (February of 2014)
Injectors Rebuilt with 520 Nozzles 225,000 miles (February of 2014)
Last weekend I finally got around to installing a Buzzken 2.5” downpipe to stock exhaust on this car. It had been leaking for a while at the flex joint and I believe the upcoming condition was present just less pronounced due to lack of concentration.
I am seeing heavy-ish white smoke (non-combusted fuel) at start up out of the tailpipe. There is also some stumbling at cold start. Today’s temp was 14F. Car started pretty fine but there is definitely at least a cylinder stumbling at start up. There are no CEL codes so I assume glow plugs are functioning sufficiently but have not pulled them to verify. Timing is at the high end of the green zone on VAGCOM. I checked the IQ yesterday and it was low at 1.8. I adjusted that so it was now getting 3.8 (leaner). This morning the symptom persisted. For about a month I have been getting an intermittent very slight hesitation and “hunting” at about 2800 rpm in 3rd gear. Now that the new downpipe is in place I can repeat that condition and usually, dependent on wind, can see a bit of white smoke out of the tailpipe at this rpm/gear. The car runs and drives great outside these issues.
Next step plan is to run a can of diesel purge directly through the pump. I did this years ago at maybe 100,000 miles. I am trying to eliminate the easy things before I move on to looking for an injector or pump issue. If that doesn't help I will also be doing a compression test although nothing looked out of place when the head was off 50,000 miles ago. I would appreciate some insight into how to most easily approach the diagnosis of he pump, injectors or anything else I may have missed. The pump is original and I have nearly exclusively run premium diesel in this car.
