vesperisk
I'm at a loss, everyone. I'm really hoping someone can help me out here. I posted a while ago about a MK3 Jetta I bought that didn't run. Leaked fuel like a mofo from the injection pump. Euro shop said I needed to reseal pump. Ended with a brand new pump. The car runs now, but only after you start it on a little brake cleaner. It smoked blue the entire way home from the shop according to my friend who was following me in his vehicle. When you crank it to start it, it'll crank and then there will be some intermittent grinding noise and it won't fire. I've thought it might be the starter, but usually those either won't work or they'll grind once the motor runs not grind while it's cranking. no codes since I got it back but I literally only drove it home and parked it.
just really at a loss here. looked around a little for some similar stuff but i cant really find much that's TDI specific or matched up with what my car is doing. anything to try or look at would be really appreciated. dont want to start throwing parts at it. anything to try is appreciated. thanks guys/gals.
