280hp is good result from VE engine with 2260VK, there isn´t really matter you use AHU/1Z or AGR based engine because main things remain same. My friend, you must understand that 2260VK is such a tiny turbo compared fe. to Holset HX35 Super. However, PD´s can´t usually rev so high than VE´s, so HX35 would not be an good option for it. It will need an compound for sure to have enough power range for PD engine I think -not sure though, since my experience from PD tuning is really limited, although i own one but it´s only reprogrammed.
Don´t know about PD injectors though, is there enough big ones available for 400hp fueling. For VE also, there isn´t at the moment, but Hflox´s Marc is working for it ( will try 5x0,4+mm and 5x0,5+mm nozzles once they are available ).
HX35 has 54/77mm compressor and 55/65mm turbine wheel. If you look and compare compressor maps from these two turbos, you can find out why´s there an difference on power output. 2260VK can´t just flow enough and there isn´t possibility to use high rpm´s with good effeciency.
350hp will not come with stock intercoler, intercooler piping, exhaust pipe, cam, head, fuel filter, fuel lines, injection pump, unmodified pistons, 2260VK ( or even modified one ). But it will come with stock rods, modified stock pistons ( valve pockets for example, are bit less than 1.5mm deeper than stock ), good setup and proper tune for sure. And by the way, i use almost stock injection timing map too. This engine is result from many long-term tdi tuners after building and having experience from tens of tuned tdi engines, though this one is built on very small time only for the way of experiment. Build it with same receipt, and you will find some numbers.
Can´t claim H-profiles would not be an good update. But question is, why should I make this update after 200 000km driving with highly tuned VE tdi without problems? Most ppl brokes their engine with "universal" tune and software without knowing AFR, EMP, intake or Exh. temps. Proper gauges gives invaluable information for software modification.
I think this conversation should be transfered for it´s own topic. Dont hate, make conversation instead and face the facts. After you make one, you can find some results. After all, still didn´t found ANY bent rods or failed pistons what i´ve asked on another topic.
Summer events are still coming, so let´s see what results we can make if engine still remains intact whole summer
Standing mile is what i expect most.
If you don´t know people personally, it does not make people foreigner. However, it´s healthy to suspect. Build it, try it, and then make conversation from it. It´s the way for progress, but you must understand basic things first.
