a little history first. The engine was rebuilt at approximately 175K.
TB flew off and everything but the short block was rebuilt by Everything Euro in Winston Salem, NC. I say that to say i do not think this is TB related. could be but unlikely. Car now has 195K
Up until Friday the car starts up instantly without hesitation every time. It has never given me any hint of trouble until that day. Simply cranks and cranks but will never fire.
New fuel filter at 175K
regular oil changes-it is due though
I checked the intake and the ASV its all clear, only the slightest build up.
I did not hook up a voltmeter/ohmeter to the 109 relay but I heard it double click when i turned the ignition. I also hear the fuel shut off clicking. I did check it with a meter and it gets its 12v
When i turn the key to on the GP light comes on for a few seconds and goes away and the Check engine light is on. If i try to turn over the engine the CEL goes away.
I have not tried to crack any fuel lines and I do not have a clear fuel line section going to the pump
and Yes i checked the fuses and they were good I am thinking that something electrical is to blame. I don't know enough about diesels and TDIs specifically to go much past what I've done with out some advice.
Thanks for all the write ups already done they were a big help!
