Hey all, First time post here, long time TDI owner. I have a 'hopefully' simple question, can a TDI engine run too cool? I noticed that my 04 Jetta TDI temperature gauge was running around 130 - 150 and not the normal 190 range today. It is very warm here in CT with temperatures around 88 with high humidity. If memory serves the temperature gauge in my car normally goes to 190 after driving for a while and stays at that temp, today was the first time I noticed it lower, much lower. Is this normal?
I am scheduled to have my timing belt and water pump replaced in a few days since my car has 95,000 miles on it but nothing is currently wrong with my car. I'm just doing standard maintenance for the belt and water pump.
Should I ask my mechanic to check the thermostat or can a stuck thermostat cause strange temp readings or sorry lower temp readings?
Thanks for any info. Doug in CT.
