ocelot
The first is the most troubling, I believe it's on the fuel pump. There is a gasket that is leaking, which in turn is leaking diesel on coolant lines below. Rubber doesn't like diesel, and I've had to replace the coolant hose twice now (it is a huge pain). At first I thought it was strange how the first coolant hose lasted 170,000 miles, and then the brand new one I replaced it with only lasted 1,000. This is the culprit:
I looked up how to take it apart in the Bentley manual and the gasket seems like it'll be pretty simple to replace. There are only four screws holding the cover, is there anything special that I need to know about removing this thing? None of the screws had any specific torque requirements in the Bentley manual. Also, where can I buy a gasket like this?
Second leak. I don't know what this is, I found the pipe in the Bentley manual and it labeled it as "crankcase breather element." Here is a picture:
At the bottom of it:
By the way it feels, I'm pretty sure that this is leaking oil. Is this another gasket issue? How should I repair it?
I'm sure I'm not the only one who has had these issues with this engine. The car is '96 model year.
TIA
TIA
