Go Back   TDIClub Forums > VW TDI Discussion Areas > Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc)
Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) Discussions about alternative fuels for use in our TDI's. This includes biodiesel WVO (Waste Vegetable Oil), SVO (Straight Vegetable Oil), BTL (Biomass to Liquid), GTL (Gas to Liquids) etc. Please note the Fuel Disclaimer.
Old November 24th, 2018, 13:59   #16
soma56
TDI(s): BEW PD
Originally Posted by Vince Waldon View Post
True, although the switch does provide a easy way to go between "stock" and "a value I have determined that works".
EXACTLY.
Another thing that occurs to me is the entire thing assumes the OEM fuel temperature sensor decreases its resistance as temperature goes up... if this is not the case adding resistance in series will trick the ECU in the wrong direction.
Presumably those that recommend a 2K additional resistor have confirmed this... but ya never know on the interwebs?!
That's a good point that I never considered. I suppose if one was inclined they could remove the sensor, add heat to it and see what the wire does in response to heat and/or cold although, given the number of positive responses in addition to those that have plugged in their VAG systems I'm confident they have it right.
soma56 is offline   Reply With Quote
Old November 24th, 2018, 14:31   #17
P2B
P2B's Avatar
Indeed, thermistors used in temperature sensing applications are usually of the NTC (negative temperature coefficient) type, i.e. resistance decreases as temperature rises. A PTC thermistor in a sensing application would be unusual.
Jettas for 35 years, TDIs for 16.
2003 Silver Jetta TDI GLS 300K PP520 RC3 6-Speed ERF
2003 Silver Jetta TDI Wagon 230K PP520 RC2
2000 Canyon Red Jetta TDI GLS 560K
P2B is offline   Reply With Quote
Old December 4th, 2018, 21:21   #18
Nevada_TDI
The hotter the ECU thinks the fuel temperature is, the more it retards the timing. The fuel temp sensor has always been the primary foe of the folks running WVO. There is one logic when setting up a WVO engine is to use larger sized nozzles and set the pump up advanced compared to stock at any given RPM. I used to ask some of the tuners I spoke with, "Why don't you code the ECU to not pull the timing back when the fuel heats up?" I never really got what I thought was a solid answer; I will say that was over ten years ago, so maybe I have forgotten.
_______________
2001 Jetta GL TDI, Tinted, Vented, No Kitty, EGR-ectomy, TDTuning, HIFLO .216's, TurboLabAmerica Hybrid 15-17/56, VCDS Hex+CAN, S-B Daily Driver 2 Clutch, DG Short Shifter, Frostheater, Baldwin Fuel Filter, Koni Orange, New Paint. Previous Diesel: 1983 Rabbit Diesel
Old July 5th, 2019, 06:14   #19
soma56
TDI(s): BEW PD
A quick update for anyone interested. I'm about 90% complete and should have it ready for a test this weekend. Here's a couple of photos working on the electrical and fuel tank I created. The display features temp gauges, an EGT gauge and a variety led indicators for various things that are powered on. The fuel tank (yes that is a little light that I installed in the tank - it makes things easier when swapping filters) was made from a mobile home water tank with a 5 gallon pail gamma seal 'affixed' to the top to allow for easy access. I have the potentiometer setup as originally discussed in this thread, however, having issues locating the correct fuel temp sensor wire to connect into (http://forums.tdiclub.com/showthread...80#post5519880).
Old July 6th, 2019, 10:29   #20
philngrayce
Fuel Economy: 53/43/49 ('02 Jetta 5 sp)
Very interesting. You’re thinking outside the box, especially with that tank. Please keep us posted on your progress.
philngrayce is offline   Reply With Quote
Old July 7th, 2019, 11:57   #21
soma56
TDI(s): BEW PD
The custom panel I made was installed today. I'll explain what all these leds and switches do later. Take note (as per an earlier discussion in this thread) - the potentiometer in the switch panel at the bottom left. The two indicators at the top right at temp sensors. One is immediately before the fuel goes into the injector and the second is located inside the veg fuel tank.
Old July 31st, 2019, 21:30   #22
WooK
TDI(s): 2006 Jetta
how's it all coming together?
WooK is offline   Reply With Quote
Old August 15th, 2019, 08:31   #23
soma56
TDI(s): BEW PD
I'm glad you asked and thanks for your patience. She's had a couple minor quirks but nothing I couldn't handle.
You can see a video update/summary here:
https://youtu.be/Xq_m-8Mphc0
A fuel gauge will be next in addition to another silicone heating system on the fuel line in the Fall (in preparation for the winter months). Aside from that I really can't think of anything else it needs. I think I overthought the fuel temp sensor resistance. If you put in a 2 or 3k ohm resistor you be fine (you don't need a potentiameter like I used). I wouldn't use a plastic tank again. It'll warp if it's not perfectly flat on the bottom (which mine wasn't because of a drainage hole at the bottom). If you have the option - use a metal tank. Disabling your EGR is a must. That's where I tapped in my EGT gauge. Anywhere between 655 and 675 degrees (Celcius) seems to indicate that there is a healthy combustion of WVO in the engine. Ironically and oddly enough - when it's been running for a bit the car likes to sit around 666 degrees. Been running perfectly fine on WVO for the past month or so and I don't foresee anything major in the future.
Old Yesterday, 08:11   #24
TDIMeister
Phd of TDIClub Enthusiast
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
https://youtu.be/TcdeeB5ZUys?t=590
Old Yesterday, 08:14   #25
TDIMeister
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
Originally Posted by soma56 View Post
Disable/delete the EGR. It's legal in Canada.
NO it is not. Just because it's not checked doesn't make it legal to disable or defeat OEM installed emission control systems.
Otis the Syncro's PD BEW 1.9 to Common Rail CJAA 2.0 Conversion Aidan.Klimenko TDI Conversions 6 November 15th, 2017 05:23
1998 Jetta with WVO conversion (and local WVO source) - $800 (Portland, OR) mikerancourt TDI Cars for Sale/Wanted 0 September 21st, 2016 13:40
Discussion Thread: Comprehensive/Technical Approach to Burning WVO T'sTDI Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 16 April 12th, 2014 16:14
Comprehensive/Technical Approach to Burning WVO Successfully T'sTDI Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 29 January 12th, 2010 12:33
Biodiesel, WVO/SVO, single/duel tank conversion in my 2005 PD Passat aticus Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 60 March 5th, 2008 13:15
Page generated in 0.15905 seconds with 12 queries
[Output: 102.30 Kb. compressed to 87.70 Kb. by saving 14.60 Kb. (14.27%)]
