Old January 14th, 2018, 16:19   #16
turbotorq
turbotorq's Avatar
TDI(s): 04 Jetta TDI
Fuel Economy: 45ish
Nice! What's the point of the silicone around the edges, does the heater not have an adhesive tear off pad
VNT17;PD150injectors;PD150intake;PD150oilcooler Tune;IMMOdelete;EGRdelete;ASVdelete w/RacePipe;KoniYellows;Frostheater;Erectonomy;DRL Disabled;HID's;VAGCOM
turbotorq is offline   Reply With Quote
Old January 14th, 2018, 16:25   #17
jimbote
jimbote's Avatar
Originally Posted by turbotorq View Post
Ok thanks I'll try it and report back. It may be a cheap option for those not wanting a frost heater
is the pump still working on your frost heater? if so maybe you can just stick it the frost heater's housing? ... that way you can still circulate the warmed coolant
jimbote is offline   Reply With Quote
Old January 14th, 2018, 16:50   #18
ScottySK
TDI(s): 03 Jetta GLS
Default Oil pan heater stuck to PD150 oil cooler for warm up
The Zerostart heaters in the kit do not have a pump, they are convection type. Just a heating element in there.
I’ve had an element die on me, must have had an airlock in the housing; bought a replacement Zerostart & swapped the heating element instead of the whole assembly.
Have KII VCDS, will trade time for good microbrews.
ScottySK is offline   Reply With Quote
Old January 14th, 2018, 17:19   #19
jimbote
jimbote's Avatar
my bad, i thought they had an integral pump
Old January 14th, 2018, 22:16   #20
turbotorq
turbotorq's Avatar
Fuel Economy: 45ish
Your absolutely right there is no pump. I was actually surprised to find this out myself. My element burned out due to airlock. Then I got black soot circulating through my coolant. Must of been the outer skin of the element. A paper filter solved that issue quick , and also plugged off quick
Oil pan stuck on! yseent VW MKIV-A4 TDIs (VE and PD) 7 April 20th, 2012 19:48
PD150 Oil cooler & Frost Heater Milage King TDI Power Enhancements 1 December 5th, 2011 20:57
PD150 Oil cooler and Frost heater Milage King VW MKIV-A4 TDIs (VE and PD) 0 November 23rd, 2011 05:49
PD150 oil cooler TDIwestfalia Private TDI Items for Sale/Wanted 2 May 27th, 2011 10:57
Engine Block / Oil Pan Heater Saves Fuel, Warm-up Time, and Wear & Tear Turbo Steve TDI Fuel Economy 44 February 19th, 2000 00:27
Page generated in 0.11752 seconds with 12 queries
[Output: 75.04 Kb. compressed to 66.45 Kb. by saving 8.60 Kb. (11.46%)]
