Old November 13th, 2019, 17:47   #1
Runstuns
TDI(s): 2003 wagon
Default Turbo underboost.
Yeah here we go,
Turbo underboost. Still go'es into limp mode,
2003 jetta tdi wagon.
Iv'e done most everything else. All vac lines, Cleaned turbo vanes. new intercooler, new actuater, Wind's up nice but still underboost.
Seem's overboost is a lot easier to fix.Will deleting the EGR help
Thanks.
Runstuns is offline   Reply With Quote
Old November 13th, 2019, 19:27   #2
STDOUBT
STDOUBT's Avatar
Deleting the EGR will not help.
How sure are you the new actuator is adjusted correctly?
In addition to vacuum lines, the connections on the charge air tract,
boost pipes-downpipe connections to and from the new IC?
You didn't mention intake manifold, but that's a side issue maybe.
Assuming you've read this:
http://forums.tdiclub.com/showthread.php?t=179589
...and knowing the codes stored could save you a bunch of time diagnosing.
2003 Jetta TDI 1.9L 5-speed
Search Tip: search this site best by using Bing: tdiclub topic
STDOUBT is offline   Reply With Quote
Turbo underboost Terblanche TDI 101 2 October 16th, 2014 13:23
turbo underboost corzy VW MKIV-A4 TDIs (VE and PD) 5 November 9th, 2013 18:03
What to do w/ P0299 turbo underboost? rustybolts VW MKIV-A4 TDIs (VE and PD) 0 September 2nd, 2012 11:06
Turbo Underboost 0Silva1 VW MKV-A5 Golf/Jettas 1 September 21st, 2011 00:58
Turbo Underboost kayak01 TDI 101 9 June 8th, 2008 20:06
Page generated in 0.14610 seconds with 11 queries
[Output: 52.63 Kb. compressed to 48.37 Kb. by saving 4.26 Kb. (8.10%)]
