Old October 28th, 2019, 13:30   #1
Rishav
Default Tdi issues
Hi guys
Need help please or Iím going to get grey with this TDI, I drive a polo 1.9 tdi, 2007 model 9n3 sport line 96 kw model 6 speed . I recently while pulling a trailer found the car just lost total power I just managed to get home , next day I used Ross tech vcds and found the car came up with the fault underboost , so checked and did a DTC clear took the car for a drive same story , if you on the 6th gear and you put foot down under 1500 rpm the car just starts dropping speed you change down and get to 4th and foot down the car starts picking up speed and then a lag again by like 2300 rpm , got back home and checked again zero fauts , checked egr valve cleaned, vacuum pipes and even pulled out Maf sensor still the same driving the car daily but itís like a donkey , I checked for leaks but nothing at all ,I did log the car using vcds, I will attach it soon to this post , thank you in advance to anyone that would kindly assist me
Thank you
Rishav is offline   Reply With Quote
Old October 28th, 2019, 15:36   #2
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
It's possible the in-tank pump is getting weak or it's done and is wearing out the tandem pump.
Old October 29th, 2019, 14:00   #3
Rishav
Iím not sure , how can I get that tested
Old October 29th, 2019, 14:15   #4
BobnOH
not-a-mechanic
VW TDI Search Engine
I believe user DanG144 has a thread on checking in-tank fuel delivery to filter
Old November 1st, 2019, 14:32   #5
Rishav
Thank you Bob
Will go search for it , havenít used the car for a distance lol scared to get stuck on the road
Old November 1st, 2019, 16:01   #6
BobnOH
not-a-mechanic
So did this just come about after you pulled the trailer? If the ECU sees any of several conditions it will revert to limp mode, not allowing the turbo to fully engage for high end power. Other than the lack of fueling, it's also possible one of the big hoses popped loose.
Old November 7th, 2019, 15:44   #7
Rishav
I have recently serviced the car , fuel filter done 1000 kms on it could it be the fuel filter restricting it ..
Sent from my iPad using Tapatalk
Old November 7th, 2019, 15:45   #8
Rishav
Yes sir only after I pulled the trailer I felt it , checked the hoses seems fine no whistling noise either
Idle issues and shuddering issues. Help! slayer3055 VW MKV-A5 Golf/Jettas 9 May 24th, 2017 13:01
2014 TDI SEL Fuel Issues and High Pressure Fuel Pump Issues khoffman31 VW Passat Family (NMS and B7) TDIs (2012+) 4 March 2nd, 2016 20:05
PD150 Studdering issues when high RMP.. Lift Pump issues? tothemax TDI Power Enhancements 14 June 15th, 2013 15:38
09a EYP Vehicle Speed Sensor issues, possibly TCM issues TreyDavis VW MKIV-A4 TDIs (VE and PD) 4 March 14th, 2012 15:40
WTT a 2001 Golf TDI Auto With Issues For a Manual TDI - N. CA ciccio70 TDI Cars for Sale/Wanted 5 November 2nd, 2010 18:42
Page generated in 0.13511 seconds with 11 queries
[Output: 85.51 Kb. compressed to 73.91 Kb. by saving 11.60 Kb. (13.57%)]
