Old September 18th, 2019, 13:39   #1
Batmanntexas
TDI(s): 1999 Jetta
Cool Another Cruise Control thread...
Hello all!
I have a 1999 Jetta, purchased it about 6 weeks ago. It has 229K miles on the ODO. I have steadily been making repairs and fixing small issues with it. Recently, within the past week, the BRAKE light illuminated in the instrument cluster (same light that illuminates when you pull the e-brake handle) and along with it the cruise stopped working. I have checked the system with VCDS and it shows proper functioning of both the brake pedal switch and clutch pedal switch. It does not show any 'state-change' for any of the functions of the cruise control switch (OFF/ON, RES, SET, etc.)
I have ordered a new cruise control/turn signal switch assembly, just waiting for it to be delivered.
One thing I have noticed, the intensity of the BRAKE light changes. When you apply the e-brake, the light gets brighter.
Is the e-brake switch tied into the curise control circuit?
Thanks in advance,
Scott
Current fleet:
2012 Camaro SS - mine
2007 Avalanche (mine)
1999 Jetta TDI (mine)
2019 Subaru Ascent (hers)
Batmanntexas is offline   Reply With Quote
Old September 18th, 2019, 13:58   #2
Vince Waldon
Vince Waldon's Avatar
Most likely you have a weak ground, and when you tighten the e-brake cable it's helping out as an additional ground. BTDT.
Don't have my MK3 manual handy at the moment, but IIRC the cluster grounds either on the multiple ground on the engine block (my best guess) or under the battery box. Brown wires, a bunch of 'em, and they like to get corroded.
Could also just be dirty contacts on the e-brake switch itself, although that tends to make the light flicker, as opposed to change intensity in a predictable fashion.
Vince Waldon Edmonton AB Canada
Canadian Grizzly's excellent low-power/limp mode troubleshooting guide
VW's TSB for scientifically tracking down parasitic current drains
Vince Waldon is offline   Reply With Quote
Old September 19th, 2019, 13:09   #3
Batmanntexas
TDI(s): 1999 Jetta
Thanks, Vince. I'll check the ground(s) and report back.
Current fleet:
Old September 19th, 2019, 14:28   #4
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
'99 was a split year for Jettas, if you have the MKIV you may want to call it a "1999.5"
Old September 19th, 2019, 20:00   #5
Batmanntexas
TDI(s): 1999 Jetta
The door tag says 01/99, so I'm guessing it is a MKIII?
Scott
Current fleet:
Old September 20th, 2019, 10:57   #6
Rob Mayercik
Car model years usually change in August, so yours might be right on the borderline. Which of the following does your car look like?
#1: https://en.wikipedia.org/wiki/Volksw...-12-2011_2.jpg
or
#2: https://en.wikipedia.org/wiki/Volksw..._Jetta_TDI.png
2002 Jetta GLS TDI Automatic
Baltic Green/Beige Leather
Rob Mayercik is offline   Reply With Quote
Old September 20th, 2019, 11:04   #7
Batmanntexas
TDI(s): 1999 Jetta
@Rob - thanks for the Wikipedia link. I have a MKIV Jetta!
Current fleet:
Old November 4th, 2019, 12:35   #8
Batmanntexas
TDI(s): 1999 Jetta
Ok, so it's been a minute since I posted the initial thread.
UPDATE: I checked the grounds underneath the battery, there were a two groups. They were solidly attached, didn't appear to be corroded, but I removed them anyway, cleaned the metal, cleaned all the ring terminals, and then reattached all grounds. --> NO CHANGE.
UPDATE: I replaced the CRUISE/TURN SIGNAL switch with a new unit, and again --> NO CHANGE.
What's really got me confused is why the BRAKE light is illuminated? Does it illuminate if the pads are worn to the wear indicators? Do the MKIV Jetta's even have electronic pad wear indication circuits?
My VCDS clearly shows that both my brake switch and clutch switch change state when depressed.
I'm assuming, that in order for the VCDS to show the change in state, it is receiving some communication from the ECM? If so, that would indicate that both my brake light switch and clutch switch are fully functional, correct?
Thanks,
Scott
Current fleet:
Old November 4th, 2019, 15:11   #9
jokila
jokila's Avatar
Fuel Economy: 52/45/40
the BRAKE light comes on if the brake fluid is low and when the ebrake is applied. The low pad wear indicator looks like an amber circle type symbol.
https://www.rac.co.uk/drive/advice/k...hat-they-mean/
Ventecomy | Heated seat lighted switch | W8 light |
Blue tint aspherical tinted mirrors | Turn signal convenience | Euro Light Switch | Rear Fog Light | DrawTite Hitch | HIDs | 520 injectors | Engine Cover mod | Homelink visor
VCDS-HEX/CAN available Houston metro area.
jokila is offline   Reply With Quote
Old November 5th, 2019, 10:44   #10
Batmanntexas
TDI(s): 1999 Jetta
Thanks for that info. Brake fluid level is fine, E-Brake is off, however the BRAKE light still remains illuminated --> and the cruise will not work.
I have looked at the schematics in my Bentley manual, but they are of little help in my opinion, at least with this issue.
Hopefully, someone else has experienced this issue and can chime in. I really miss my cruise control....
-Scott
Current fleet:
99.5 cruise control control swap Trimmy VW MKIV-A4 TDIs (VE and PD) 2 January 21st, 2015 16:50
Yet another cruise control thread.... Fallon VW MKIV-A4 TDIs (VE and PD) 3 June 3rd, 2011 21:37
Cruise Control losing control Knoxville TDI 101 15 April 14th, 2011 12:12
Cruise Control Drops, Traction Control Light Flashes Alchemy VW B5 Passat TDIs 10 January 2nd, 2011 21:07
No cruise control, with cruise light on gotdiesel TDI 101 14 July 2nd, 2009 18:57
Page generated in 0.16079 seconds with 11 queries
[Output: 98.74 Kb. compressed to 83.90 Kb. by saving 14.84 Kb. (15.03%)]
