Old June 30th, 2019, 20:36   #1
yahjnby
Default Stripped harmonic balancer bolt
Trying to work on my engine and I stripped two of the Allen bolts on my harmonic balancer. I have not bothered trying the other two yet.
Anyone have experience dealing with these things when they strip. I have begun to hate Allen bolts on VW‘s with a white hot passion.
Fortunately I’m not in a rush. I’m hoping somebody here has been successful with something. I do have something that I used on stripped Valve cover bolts, but I don’t think the little screw on caps are going to fit in the space of the harmonic balancer, let alone allow me to stabilize it while I crank on it.
1998 new beetle TDI
yahjnby is offline   Reply With Quote
Old June 30th, 2019, 20:49   #2
mr.loops
Ya you wonít be able to get a bolt extractor in there - too tight
I would grab a torx bit ( find one that is a good tight fit) and hammer it into the offending hole.
mr.loops is offline   Reply With Quote
Old June 30th, 2019, 20:58   #3
iamatt
iamatt's Avatar
Fuel Economy: 45
I'd tack weld the bit you used on there if you can't get extractor in there.
Sent from my FRD-L14 using Tapatalk
2014 Jetta TDI sedan (new) ,2014 TDI Jetta Sport Wagon 6MT (Flooded) Amsoil HDD3000 20K OCI, GSP Mod (RIP Rosie 4/4/2015), 2011 Toyota 4 Runner SR5 (Flooded), 2007 Duramax (Flooded), slightly modded GSPv2 is here, Bellatrix "Bella" Hunting God's County, katygsp.com
Amsoil Dealer -
http://www.texas-synthetics.com
iamatt is offline   Reply With Quote
Old July 1st, 2019, 04:19   #4
Tdijarhead
Use a hammer and a piece of rod on them. I always give each bolt two or three solid wacks with this method. So far I’ve never had one strip out.
As far as the already stripped ones , tack weld as mentioned, hammering a torx or next size Allen into the hole, or hammering a socket over the head. Before trying any of those methods hit those stripped bolts a I described above, it helps to break them loose.
Of course you will want to replace all 4 with new bolts.
Tdijarhead is offline   Reply With Quote
Old July 1st, 2019, 05:41   #5
dogdots
dogdots's Avatar
TDI(s): None
12mm 12 point socket driven on with a hammer will get those out. Before trying to loosen the 2 you haven't yet, place the 6mm allen socket in the head and tap several times with a hammer, then use an air or electric impact to remove them.
You can also drill off the head of the stripped ones, they are pretty soft and drill easily. The 12mm 12 point socket is the cheapest and easiest way.
Non VW: 2011 BMW 335D and 2011 BMW X5 35D, 1977 MB 280SL, 1979 Chevy C20 6 banger with 51k original miles, 1977 Chevy C10 454 bought new by wife's grandfather.
www.kansascitytdi.com
dogdots is offline   Reply With Quote
Old July 1st, 2019, 12:31   #6
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
The one good thing with the socket head screws, they're easy to drill off cause they're pre-centered. They make a lot of different extraction solutions, in the mean time hit them with PB Blaster (or better) followed by hard raps as jarhead suggests, repeat.
Old July 1st, 2019, 14:01   #7
Powder Hound
Powder Hound's Avatar
I like the Irwin bit that goes around the head. They always work for these bolts. Well, they've always worked for me. There's a first time for everything...
Cheers,
PH
Old July 1st, 2019, 14:36   #8
csstevej
Yeah I’ve done the socket and drilling the head off. Both work great, once you drill the head off and dampener removed the screws pretty much come out with your hand.
2001 golf auto to 5 speed manual swap,G60/VR6 clutch setup,coolant migration mod.
csstevej is offline   Reply With Quote
Old July 1st, 2019, 18:22   #9
GEFP
I've had success with using an air hammer with a punch point in the center of the bolt. Just put on a small vice grip onto the head and they turn out quite easy while hammering with the air chisel.
GEFP is offline   Reply With Quote
Old July 2nd, 2019, 08:09   #10
jokila
jokila's Avatar
Fuel Economy: 52/45/40
Cheers,
PH
I agree with this. I have used Irwin's for this kind of purpose for many years. There is enough room.
I use a hammer to tap the extractor bit into the soft bolt head, then remove with the 3/8" socket and extension.
Ventecomy | Heated seat lighted switch | W8 light |
Blue tint aspherical tinted mirrors | Turn signal convenience | Euro Light Switch | Rear Fog Light | DrawTite Hitch | HIDs | 520 injectors | Engine Cover mod | Homelink visor
VCDS-HEX/CAN available Houston metro area.
jokila is offline   Reply With Quote
Old July 2nd, 2019, 08:12   #11
williambill
I second the 12mm socket method. Works REALLY well and doesn’t damage anything.
William Bill
-2002 Jetta TDI
-2002 ford F250 7.3L
-1984 Mazda B2200 2.2L NA Diesel
williambill is offline   Reply With Quote
Old July 3rd, 2019, 04:18   #12
yahjnby
Thanks all. I’m getting back to it this weekend, and PB blasting in the meantime. I’ll let you know what I end up trying and how it works out.
Old July 3rd, 2019, 11:42   #13
1854sailor
Resident Curmudgeon
1854sailor's Avatar
My question is how did you strip them out? Were you using the correct size metric hex key or the closest SAE size that would fit?
-George Bernard Shaw
Old July 3rd, 2019, 11:44   #14
jokila
jokila's Avatar
Originally Posted by yahjnby View Post
Thanks all. Iím getting back to it this weekend, and PB blasting in the meantime. Iíll let you know what I end up trying and how it works out.
When you install them don't overtorque them. It's only 18 ft lbs.
Old July 3rd, 2019, 11:51   #15
1854sailor
Resident Curmudgeon
1854sailor's Avatar
For the ALH it is actually 10Nm (~7.5 ft-lb) + 1/4 turn. And they should be replaced.
Stripped Harmonic Balancer Bolt, Doh! ahardy4 TDI 101 33 June 8th, 2019 06:56
Stripped bolt remover, harmonic balancer Bob702 VW MKIV-A4 TDIs (VE and PD) 26 March 8th, 2015 18:56
Harmonic balancer bolts stripped Vegified TDi VW MKIV-A4 TDIs (VE and PD) 22 September 16th, 2013 23:13
Harmonic balancer - stripped bolts Jettascuba TDI 101 10 October 13th, 2009 11:20
Installing TB stripped harmonic balancer bolt terrydtdi TDI 101 7 July 23rd, 2007 17:25
Page generated in 0.15918 seconds with 11 queries
[Output: 129.73 Kb. compressed to 108.12 Kb. by saving 21.62 Kb. (16.66%)]
