Old December 23rd, 2015, 17:44   #61
06TDI13
The guy I got it from has a lot and works with TDI's a lot. he recommended every 4k and that's what I have stuck to. I just turned 190 today and I have new filters on their way for a tune up this weekend. I am on the original cam and would prefer to not have to change that.
2006 Jetta TDI 5 spd, MBRP 3" cat back exhaust, Rocket Chip tune
06TDI13 is offline   Reply With Quote
Old December 24th, 2015, 10:10   #62
GreenLantern_TDI
GreenLantern_TDI's Avatar
Fuel Economy: Mid 40s
Changing your oil every 4000 miles is doing damage to your engine. Research this. Using a good 5w40 diesel motor oil will protect your cam at the recommended 10,000 mile oil change interval. I change my oil every 20k miles.
Read this page.
http://forums.tdiclub.com/showthread...=283709&page=2
http://forums.tdiclub.com/showthread.php?t=453857
2015 Golf SEL. Malone DSG Tune. H6 AGM East Penn Battery. Frost Heater. Ares Skid Plate. Fumoto Valve. PentoIII.
GreenLantern_TDI is offline   Reply With Quote
Old December 24th, 2015, 12:33   #63
06TDI13
well then I guess I will switch to 10k intervals.
Old December 24th, 2015, 13:55   #64
MPLSTDI
MPLSTDI's Avatar
TDI(s): 06 Jetta DSG
Fuel Economy: Max 54, 44 avg
I'm at 172k, and just did an outer CV boot. I didn't see that in anyone's list but it's cheap.
DMF at 120k, Front Driver's wheel bearing at 150k, injector harness at 105k, driver's door harness at 100k, original brakes.
I would be over 200k if I had not moved last year.... Only putting on 10k a year now, could be driving this car for the next 30 years!
Member of the TDT for PD Mafia
2006 Jetta TDI DSG base 0 - heated seats Shadow Blue 212K ScangaugeII Hidden hitch GDE HOT/ECO Tune
MPLSTDI is offline   Reply With Quote
Old December 24th, 2015, 15:01   #65
morpwr
Fuel Economy: 40-60
Smile 06 brm dsg
467,000kms. New DSG flywheel at 445,000. Transmision and DSG flywheel replaced by previously owner at 166,00. Turbo at 417,00 (original), and cam (original) timing and surpentine belt, tensioners, idler pulleys and water pump. New DSG flywheel noisier than old VW one. Runs and starts great average 900kms per tank. Need some paint next spring.
morpwr is offline   Reply With Quote
Old December 30th, 2015, 16:37   #66
jayp111
TDI(s): n/a
Fuel Economy: n/a
Not quite 300k
Nothing unexpected...sold car....hope to go to 500k
"All that is necessary for the triumph of evil is that good men do nothing." (Edmund Burke)
Never underestimate the power of stupid people in large groups...
"Political Correctness is a doctrine, fostered by a delusional, illogical, liberal minority and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
VAG Com
jayp111 is offline   Reply With Quote
Old January 15th, 2016, 07:17   #67
TonyJetta
Fuel Economy: A5: 36mpg Avg / A6: 39
215k
Major issues:
Cam replaced twice. Every 100k!
DSG DMF replaced @ 80k.
Sent from my Diesel Fleet
Diesel fleet: '15 Jetta TDI SE; '06 Jetta, TDI, DSG-5sp Conversion; '06 DC Cummins, CC/LB/DRW; Past Project car! Troubleshooting Links: Trusted TDI Mechanics IP Timing Timing Belt FAQ A3/B4 Low Power Cyl Head Repair Fault Codes What you have just read is an opinion...take it as you see fit!
TonyJetta is offline   Reply With Quote
Old January 15th, 2016, 19:13   #68
hip001
hip001's Avatar
Fuel Economy: 06 Jetta: 41mpg avg
2006 Jetta tdi DSG 261k
Owned since 149k
DMF right before I bought it.
Frank's Colt cam @ 149k
Malone 1.5 tune w/egr delete @ 200k
Headliner 240k
245k wife wanted in dash GPS. Installed Panasonic & love it!
Drivers door harness 250k
Airbag light been on since we bought her @149k. had the dealer check @250k said clock spring connection loose. Stayed off for 6 months then back on again.
Glow plug harness 260k
Zip tie mod 262k
Has vibration when accelerating in 3rd,4th, &5th. No idea what is causing it?? Ideas???
"In God We Trust"
2006 Jetta TDI 311k miles
2002 Audi TT Quatro 35k...sold
82,84,85,86 Mercedes diesels.....sold
Beetle, Golf, Jetta, Passat,Tdi's..sold
hip001 is offline   Reply With Quote
Old January 15th, 2016, 21:52   #69
CLLARK1
Just purchased an 06 Jetta TDI package 1.VTEX interior in great shape ,body in good shape.The paint is fair few scratches.The previous owner said it had flywheel noise so far I have put about 500 miles no noise.It has a EGR cooler delete with Malone Stage 2.It came with fuel filter,oil filter,flashzilla,Darkside dogbone mount,OEM DSG filter change kit.Also has new AGM Advanced auto battery and new tires from Discount Tires with warranty.Timing belt has about 20,000 miles on it.The vehicle has 249,000 miles on it runs great no leaks.I have no history as for as camshafts or turbos.I purchased it for 2500 dollars so I can afford to put a few dollars into it.Not as fun as my 2010 Sportwagen but nice car overall.
CLLARK1 is offline   Reply With Quote
Old January 16th, 2016, 09:17   #70
spyder982
TDI(s): 2006
181k been a big pos - just trying to get $ out of it. I'll try to remember all the issues without digging out the receipt book.
52k airbag lights come on - 1 recall and 6 trips to dealer later it's still on at 181k. Gave up that they'll ever work.
Speedo off 5 mph but vw said it was in spec.
85k egr failure and heater core hoses replaced due to expansion from "egr oil leak"
Radio magically adjusts volume in its own and button peeling. Vw reset.
55k Headliner falling down, vw says all posters on tdi club getting theirs repaired are liars. Says I haven't given dealer enough service or owned enough vws to qualify ( family has had 7??) Won't cover under extended service warranty.
45k Speakers fail in door. One dealer replaces one, another dealer says it's my fault and won't replace.
52k door lock fails. Vw replaces but doesn't match other 3 locks. Dealer won't replace all car starts to look mismatched.
120k dmf fails
125k drivers door harness starts to fail and I patch together
130k slowly failing ac finally dies, replace ref press sensor (thanks to this site)
135k drivers harness dies and I replace.
140k mechTronic starts acting up shifting hard.
142k replace drivers drive shaft
145k replace drivers hub
155k egr fails. Mistake on diagnosing on my part but change vacuum tree solenoid, several other solenoids, mass airflow sensor, and up with egr delete.
160k back door latch breaks have to remove skins and replace.
175k alternator pulley dies - replacement part now dying as well (thought Napa sold good parts?)
178k water in passenger side floor board. Check all sunroof drains. Discover sun roof magically opens on its own while car is parked. Noticed this while driving often assume switch has loose connection. Jimmy switch and roof closes for good but scared to move switch as turning to correct function doesn't always work.
Many many little things since we bought certified prepared at 42k. Constant sulfer exhaust smell around the car, low fuel light doesn't work, left lights on warning works when it wants to, replacement dmf is chattering now, water leak on roof around antenna, best mpg was 50 once. Otherwise it's always 40-42 no matter how slow you drive it or aired up tires are. Speedo is off so you're guessing, airbags have never worked, dsg won't shift out of drive from time to time and bangs into 2/3rd, fuel pump gasket leaking. We drive this 70 miles a day for the last couple of years so while these issues seem spread out, in reality they're almost constant.
Neat for all you guys who got a good product! The 300k+ group is insane. Unfortunately this will be my last vw. Any fuel savings over a corolla were eaten up with the dmf/egr repairs.
spyder982 is offline   Reply With Quote
Old January 16th, 2016, 09:41   #71
logdrum
I just got one with 183k. Cam, TB, FW and clutch and brakes changed within the last 20k miles and I have all the service records. I need to deal with the EGR valve hiss and then flash it with GDE. And then put better tires on the summer rims.
Sent from my LG-H811 using Tapatalk
logdrum is offline   Reply With Quote
Old January 16th, 2016, 18:07   #72
narongc73
BRM's sure like to eat cams. 183k and mine is still good. People keep saying changing your oil early is doing damage, blah blah. I change mine at 7-8k, mostly hwy driving. My cam is still perfect last time I checked at 170k. Its probably all luck though
narongc73 is offline   Reply With Quote
Old January 31st, 2016, 19:46   #73
derandjer
2006 Jetta TDI, 235,000 miles.
Had since brand new
original Cam lasted until this week, now in the middle of the rebuild in my driveway
Turbo replaced at 150,000
Transmission replaced at 180,000
Was averaging 45mpg
Great car and loving the longevity my fellow owners are experiencing
Two German machines:
2006 V-Dub Jetta TDI - 234,000 miles so far
1987 Porsche 911 Carrera (sold)
derandjer is offline   Reply With Quote
Old February 1st, 2016, 09:14   #74
Diesel126
285,000 still runs strong. I do Vw recommend oil and DSG change intervals.
Rotella T6
Diesel126 is offline   Reply With Quote
Old February 14th, 2018, 23:04   #75
munkee
Fuel Economy: 44
Default 303k
Bought an 06 with 260k. Had all rust repaired under the 12 year corrosion warranty. Replaced dmf at 270, just did cam and timing belt at 299. Seems to be running better than ever, next it's the egr delete ( need to heal up from shoulder surgery first). Like it so much more than my all, more roomy cab.
munkee is offline   Reply With Quote
06 brm jetta. High mileage. 38326. Middle tn ondwater TDI Cars for Sale/Wanted 3 August 26th, 2014 03:25
06 Jetta BRM high altitude issues kdawg89 VW MKV-A5 Golf/Jettas 1 April 23rd, 2014 18:18
New TDI owner. 06 Jetta (auto) high mileage Created VW MKV-A5 Golf/Jettas 5 April 3rd, 2013 06:48
Buy a high mileage 06 jetta? vwcruisn VW MKV-A5 Golf/Jettas 18 August 28th, 2010 15:20
Popular High Mileage contest - Under 200K need not apply ICNTDRV TDI 101 20 August 8th, 2006 22:13
Page generated in 0.17653 seconds with 11 queries
[Output: 128.42 Kb. compressed to 107.40 Kb. by saving 21.02 Kb. (16.37%)]
