Old August 13th, 2015, 15:20   #1
OMALLEY_808
Default 06 BRM JETTA's - High Mileage (200k+) Post it!
Hey curious to see how long this car is going to last! Post up the following if you have over 200k miles!
Mileage: 260k Miles
Avg MPG: 550-600miles to a tank beating on it around town
How many Cams: 1 @ 200k Miles
How many Turbos: 1 @ 200k Miles (Old turbo was still good but VNT had a lot of play)
Performance Adders: Malone stage 2, EGR delete, SMF & Sachs clutch,
Any other major issues: None
06 Jetta BRM - Malone Stage 2 - GTI Struts - GTI Grills - Eibach Sportline Springs - 6k HID Headlights
OMALLEY_808 is offline   Reply With Quote
Old August 13th, 2015, 17:32   #2
MyAvocation
MyAvocation's Avatar
Several members above 300K and at least one above 400K. I'm only at 286K and got 54 MPG on the morning commute. BRM is a solid motor with the proper oil, cam and DMF.
"Never trust Internet quotes." - John F. Kennedy
MyAvocation is offline   Reply With Quote
Old August 13th, 2015, 20:58   #3
chessmyantidrug
TDI(s): 2006 Jetta
Mine is almost to 186K. It had a little over 58K when I bought it in 2009. I'm about to go on a west coast road trip making stops in Denver, Portland and Seattle. The only things I've replaced have been brakes and tires. I haven't had any engine-related problems except for for when I overcharged my A/C last summer. Good thing there was a car shop a block away from my hotel in Phoenix.
I usually get around 600 miles a tank delivering pizza. On road trips, I usually get between 650 and 700 miles on a tank. My personal best is about 711 and that was going the speed limit from Oklahoma City to Omaha, then to Kansas City. I had to fill up halfway to Kansas City. I've only gone over 700 miles twice. I'm sure if I tried I could get closer to 750 miles on a tank, but time is usually a more important resource than diesel on my road trips.
chessmyantidrug is offline   Reply With Quote
Old August 13th, 2015, 21:48   #4
BRMTDI
I'm at 205k, pushing 180whp, 360wtq, tuned and no issues,
BRMTDI is offline   Reply With Quote
Old August 13th, 2015, 23:08   #5
MyAvocation
Your tank holds 16 gallons.
Old August 14th, 2015, 05:09   #6
newlitemotorist
413k
3rd cam at 398k
2nd dmf at 300k
2nd turbo at 350k
2nd alt. Pulley at 408k
No power adders
400 psi compression on all 4 cylinders. Uses about a quart of oil every 4000 miles. Runs like a top that has a well seasoned edge...lol Definitely my favorite TDI so far.
Also, Dsg and mechetronics are original and it shifts fine!
newlitemotorist is offline   Reply With Quote
Old August 14th, 2015, 05:12   #7
BRMTDI
Our tanks hold about 13.5 gallons..or 14 if you round it off sort of.
Old August 14th, 2015, 05:21   #8
deeslman
I'll play,
235,000 miles.
16 months of ownership 74,000 miles
Has not broken a sweat.
Front pass wheel and hub bearing.
About to do drivers rear bearing.
Completely satisfied with car..............
deeslman is offline   Reply With Quote
Old August 14th, 2015, 12:14   #9
MyAvocation
Manual says 14.5 gallons. Regarding 16 gal, check log entries #62 and 64 on my Fuelly link. And yes, I refill at the same station and pump unless out of town.
Old August 14th, 2015, 14:51   #10
chessmyantidrug
TDI(s): 2006 Jetta
I find this hard to believe. Whenever my fuel light comes on, I know I can go between 60 and 70 miles before I'm in danger of running completely out of diesel. Filling to the cap, I've never pumped much more than 15 gallons at once. I'm not willing to risk burning my fuel pump to test your 16-gallon theory.
Old August 14th, 2015, 15:17   #11
chronoreverse
It's definitely more than 13.5 gallons. I've filled up at 52 litres before and that's already 13.7 gallons. 16 gallons seems extremely optimistic but 14.5, like it says in the manual, seems to be a good bet.
chronoreverse is offline   Reply With Quote
Old August 14th, 2015, 17:30   #12
Earthman
Earthman's Avatar
Fuel Economy: 47ish
Default still going
Got the 2005.5 version of the BRM mk5 and the car is solid at 260,000 miles.
2nd turbo @ 250k
2nd cam@ 142k
Clutch @ 182k
Tuned with bigger turbo and stronger clutch. Pushing about 260 ft-lb torque.
I see no reason 300k+ is not possible.
2005.5 Graphite Blue pkg 0 Jetta TDI, 5M, DG panzer plate, BCed GLI grille, E-code Hella headlights, projector fogs, Neuspeed sport springs/ Koni Strt. Upgraded cam, GTB1749 turbo, pd150 injectors, Malone St4 tune.
271,xxx miles, 46.5 mpg avg.
Earthman is offline   Reply With Quote
Old August 15th, 2015, 00:52   #13
MyAvocation
Hmmm, where to begin?
Theory or fact? Pumping 16 gallons is old news and I'm not the first.
You should read your manual: 1.9 gal reserve at low fuel warning.
Speaking of facts, low fuel burning the pump is a myth, but you're free to believe what you want... Like those doing 5k OCIs.
Old August 15th, 2015, 13:54   #14
chessmyantidrug
TDI(s): 2006 Jetta
My sister ran her car dry once and the fuel pump failed as a result. Call that a myth if you want, but I call it cause and effect.
Whenever my fuel light comes on, I go another 60 to 70 miles and usually pump around 15 gallons in these instances. Once again, I'm not risking my fuel pump to test your theory.
Old August 15th, 2015, 23:20   #15
MyAvocation
Did I mention your sisters whatever? Proper context... VW. I'm trying to be nice, do the math... 1.9 x [current MPG] = >70. Facts can be stubborn, people more so.
06 brm jetta. High mileage. 38326. Middle tn ondwater TDI Cars for Sale/Wanted 3 August 26th, 2014 03:25
06 Jetta BRM high altitude issues kdawg89 VW MKV-A5 Golf/Jettas 1 April 23rd, 2014 18:18
New TDI owner. 06 Jetta (auto) high mileage Created VW MKV-A5 Golf/Jettas 5 April 3rd, 2013 06:48
Buy a high mileage 06 jetta? vwcruisn VW MKV-A5 Golf/Jettas 18 August 28th, 2010 15:20
Popular High Mileage contest - Under 200K need not apply ICNTDRV TDI 101 20 August 8th, 2006 22:13
Page generated in 0.10162 seconds with 11 queries
[Output: 126.50 Kb. compressed to 105.42 Kb. by saving 21.08 Kb. (16.66%)]
