***** Major edit *****
Ok guys ... first of all, let me apologize for a big mess in my explanations. This is a product developed by my uncle's company in Korea. So far, until recently, it was licensed to sell in Japan exclusively under the brand name CARUP. The license has expired, and now they are selling it as CAR-BRA (Car Bio Reduction Activity).
For those of you who don't know what this is ...
It's a product that improves mileage, performance, and reduce emissions.
So far, my poor attempt to translate and explain the inner workings of this device (from Korean to English) has been a disaster - and I deserved all the flaming for it (and the non-sense).
I thought I got it, but after much criticism from you guys, I pretty much forced the company to hire a professional translator to get the explanation right.
So... here we go. - I'm copy-pasting this information from the Powerpoint presentation file. If anyone wants to read the actual file, email me, and I'll try to send it over (if you have a big email account).
<font color="red"> Summary of Carbra: </font>
Development of fuel saver equipped with revolutionary function and easy-to-use.
We could know the principle after we observed that car fuel
efficiency increases 10~15%due to enhancement of engine combustion
andexisting exhaust decreases by coatingexternal surfaces of cylinder block
of gasoline or diesel engine with paint (Coating paint that generates minus ion)
containing Brita ore powder etc.
We investigated this as a measure to enhance CO2 gas due to contraction of Kyoto protocol
Primary subject : We designated it as enhancing car fuel efficiency
<font color="red"> * The reason why fuel efficiency rises when you put CAR-BRA into auxiliary tank of cooling water </font>
Asakawa effect : Flame combustion speed rises when electric field (magnetic field) is formed around flame.
* Left candle: Before magnetic field is generated
* Right candle: After magnetic field is generated
<font color="red"> * Theory about enhancement for flame effect through electric field or magnetic field </font>
1) Malinowski : Flame combustion speed of combined fire(여혼합화재, 予混合火災 rises through electric field.
A.E.malinowski : J. Chimie Physique(U.S.S.R) 21, p469(1924)
2) Guenault et al, : Enhancement of combustion speed is achieved by increase of fire area through applying electric field.
This will increase combustion speed in appearance.
E.M Guenault & R. V. Wheeler: J. Chem.soc.2, p195(1931) E.M Guenault & R. V. Wheeler: J. Chem.soc.2, p2788(1932)
3) Calocate et al : Stability of torrent combined fire by providing magnetic field.
H.F.Calocate & R.N.Pease : Ind. Engng Chem. Ing,Edn. 43,1, p2726(1951)
4) Kono et al, : Control of soot particle generation may be possible through electric field.
M.kono,K. Imamura. & S. Kumagai: 18th Symp.(Int)on Combustion, pp. 1167-1174(1971)
5) Asakawa : Combustion speeds up by providing fire with electric field. 「Asakawa effect」
"Asakawa Effect" Yuukichi Asakawa : Nature, vol361, No.1557, pp220-221, May20,(1976).
6) Asakawa Yukichi : Fire shape had been found to change and combustion speed also had been found to vary
when we apply electric field to combustion field. We discuss application to combustion, heat transfer and speed
up of vaporization in detail. Study of electric heat, 26, 101, p134(1987)
7) Fujita et al. : Oxygen supply for fire has been increased and time for overall combustion is reduced by applying magnetic field.
O. Fujita et al,: 27th Symp.(iNT)on Combustion,(in print)(q998)
<font color="red"> * Role of CAR-BRA at auxiliary tank of cooling water </font>
1. Install CAR-BRA at auxiliary tank
2. Cooling water at the inside of auxiliary tank is transformed into negative ion water
3. - Engine startup -
Temperature increase of cooling water due to raised engine heat
4. Cooling water circulates through auxiliary tank
5. Overall cooling water is transformed into negative ion water
Amount of negative ion generated ncreases by heating :
Exhaust amount of minus increases by
temperature rise, but change isn’t so apparent at 30∼60℃. It increases 20∼30 times when Temperature raised to 100℃
(Painting technology : Volume 144 July, August 2003 p33~)
<font color="red"> Effect of CAR-BRA </font>
1. Fuel saving effect
2. Noise reduction of engine
rotation
3. Increase of horsepower
4. Drastically reducing exhaust
gas (CO, HC)
5. Reducing frequency of
engine oil exchanges
There may be a difference per conditions like as engine displacement, year type, manufacturer etc., but effect gets maximized in case of old cars. And almost fuel saving effects are above 20%.
Promoting perfect combustion through magnetic field of negative ion thus inducing drastic reduction of exhaust gas and enhancement of horsepower
The attached content shows that maximum torque value rises remarkably after one month.
Exhaust Reduction Test:
Authentication Marks:
Ok, that's about it ...
So I hope this makes better sense to you guys ...
But I know some of you guys might still have reserve thoughts about it - that it wont work, .. so, I'm still going to go ahead with the independent tests by 3 testors from here, as well as get a dyno run by someone credible from the forum - in Toronto.
I'll post up those when I Get them.
Thanks for putting up with me so far.
All your comments (excluding racial / faimly related) are very welcome.
rotation
gas (CO, HC)
