Dcrowley69
Hi. Is there any way to vent outside air into the cabin without having to turn the fan on? 2006.5 Jetta. Thanks.
I do not.Mike_Van said:Dcrowley69,
Do you, or don't you get fresh air from the two middle dash vents (assuming they are open) when the fan is on speed 0, RECIRC is OFF, and the car is in motion?
I <3 you.Drivbiwire said:Use the fan, there is NO penalty in terms of load on the motor with the fan running.
Consider how many kilowatts are being produced my the motor only to extract a few watts or 1/10,000th of the total engine output with the fan on 1 vs 0.
You have more drag by opening a window than what you would be penalized in fuel consumption by running the fan.
To put it more bluntly, if you can't afford the one gram of fuel extra per 24 hours of run time then you may want to sell the car and ride a bike...Then again you may start asking how to reduce the tire wear on the said bike in which case that's between you and the bike forum that supports the type of bike you purchase.
Do you not see the lunacy in asking this type of question?
Run the damn fan!
DB
Dude. I could care less about fuel consumption in this respect. I'm averaging 50 MPG, and am quite pleased with that. I just think it would be nice to be able to listen to the radio at "normal" decibles, with the windows and sunroof shut, and without the fan turned up full blast to get a decent breeze flowing.Drivbiwire said:Use the fan, there is NO penalty in terms of load on the motor with the fan running.
Run the damn fan!
DB
It should not be like that your controls to the flap that change where the air goes may need adjusted. On my 01 I can put is on 1 and feel it fine on every car I have had it has been so. I will open the Passenger side window about 3 in. and turn the fan on low and be fin with very little noise.larithmos said:My fan is only noticeable on 3 and 4... on 1 I can't tell the difference between on and off. Driving noises are going to drown out the radio more than the fan at most speeds.
replace drivers window with plexiglass with a NASCAR style scoop intake ?Dcrowley69 said:Dude. I could care less about fuel consumption in this respect. I'm averaging 50 MPG, and am quite pleased with that. I just think it would be nice to be able to listen to the radio at "normal" decibles, with the windows and sunroof shut, and without the fan turned up full blast to get a decent breeze flowing.
