Hello.
I need a formula to calculate the quantity of fuel are forced through a nozzle at certain time on a certain pressure.
I have Bump quantity per injection.
0.20ml
injector pressure.
250 bar.
injecting time.
1 milisecond.
why i need it?
I want to find optimal nozzel ends for my engine.
Two methods of measuring flow: Raw and installed method.
Raw uses the nozzles physical characteristics when mounted to a test apparatus to generate a raw flow analysis using an ISO 4113 fluid at specific pressures and temperatures. This measures the constant flow volume and can be used to determine cavitation effects of the nozzle with the needle at maximum Min, Mid and Maximum lift.
Installed volumes generally use 5 pressure ranges of the pump system employed. Different pumps have different pressure/volume flow curves irrespective of the nozzle installed. Injector duration is a function of pump output in applications not employing CR or PD control systems. Having a separate model to control injector duration while maintaining a precise constant pressure and temperature is mandatory to generate any meaningful data.
You mention 250 bar, but the problem is and you don't seem to realize this is that the injection pump does not operate using a constant pressure. The pressure generated by the pump may be as low as 300-350 bar at idle (despite your injector being stamped 250bar) rising to over 1000 bar or more at full load.
The constant variation of pressure makes it all but impossible to use the pump on the engine to generate flow data, again pressure must be regulated to ultra precise standards to eliminate volume variations.
For the most part raw flow data can be used to determine your original applications flow range. This can be used to extrapolate a rough estimate for desired performance goals for any particular application.
