BradleyRas
Ok....I solved the leaking injector problem (removed fuel line from injector, reinstalled it and no more leak), changed my driver side headlamp bulb (which required me to remove the battery cause I have gorilla hands) and in the process I broke the positive battery terminal tension bolt...
Now when I start the car, sometimes I have to crank it a second time..it turns over and almost starts but doesn't... AND
sometimes while driving, I'll get three beeps followed by an ABS light and flashing BRAKE light on the dash.....***? Could the broken battery terminal be the cause for this? I'm going to replace the battery terminal tension bolt tomorrow when the stealershit opens..
Can you please give me your thoughts about this? Could it be the battery terminal? Am I about to experience a problem with my ABS or brakes? /images/graemlins/confused.gif /images/graemlins/confused.gif /images/graemlins/confused.gif
