armyschus
Looking for help from the gurus on this one. I replaced the TB with a Dieselgeek kit today in my 2005 Jetta TDI. Used the same procedure from the club that I did for the 100K TB change. Car will not start and VCDC has an error for the camshaft positoin sensor.
Here is the exact report
1 Fault Found:
19464 - Camshaft Position Sensor (G40)
P3008 - 000 - Signal Out of Range
Freeze Frame:
RPM: 252 /min
Torque: 168.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 9.88 V
Bin. Bits: 00101100
Idle Stabilization: 0.0°KW
(no units): 35.0
Readiness: 0 0 1 1 1
I am almost complete with tearing everything back down and going through the installation again.
Please advise on what has caused this. Camshaft off by a small margin with the tensioner was set? Going back to the Army auto craft shop in the morning at 7am.
1 Fault Found:
Freeze Frame:
RPM: 252 /min
Torque: 168.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 9.88 V
Bin. Bits: 00101100
(no units): 35.0
