NewOwner
Hi Gurus,
Good Morning. Last night I was doing an oil change and want to check the oil level before I change the oil. After stopping the car waited for 10 mins or so then checked the oil level and it is lower (the level is at first bend on the dipstick). I do oil changes after every 10k miles. Is it common to loose some oil after 10k miles?
I don't see any leaks and no smoke. It is 02 Jetta with 02M transmission at 185K miles. I appreciate your advice. Thank you!!
