Bob Schaefer
- Joined
- Mar 30, 2006
On a long trip water pump failed at 53k mi. Engine overheated but shut down in time to prevent any damage. The failed pump has a plastic impeller, pressed onto a knurled shaft. When cool the pumps works fine. When it got to operating temp the heater wouldn't put out hot air. Pump replaced along with timing belt and tensioner at dealer in TN. the new pump also has a plastic impeller. I looked at a new pump when I got home and the impeller was metal and am told it costs $9.00 more than plastic type.Anyone had a premature failure of this type? What is the average mileage at failure? Was I lucky or what? PT warranty covered replacment.
Bob Schaefer
04 Jetta GLS TDI Ventectomy
Bob Schaefer
