Hasenwerk
Vendor , w/Business number
- Joined
- Nov 28, 2003
- Location
- Quesnel, BC
- TDI
- 1982 Cabriolet (BEW|VNT17|Stage4), 1989 VW TriStar Syncro soon-to-be CR TDI (CBEA), 2001 Ford Ranger Edge 4x4 (ALH|VNT17|R520|Stage4)
My Golf Country AHU TDI swap is complete and runs well, but now I want to install some 0.216mm nozzles that I have. Each injector was a royal pain in the ass to remove due to corrosion between the two dissimular metals. I can not for the life of me remove injector #2. It spins relitively freely in the hole, but I can not get any up and down movement to happen. As of yet I have not broke the injector, but I don't want to do that. I have soaked the area in "liquid wrench" for a few days and have also sprayed some WD-40 to make things a little more slippery. I have even built a 15mm wrench with a 90 degree bend in it with a T handle on the top and have had no success with upward pulling using that tool.
There has to be someone out there with a few suggestions?
Thanks in advance!
Thanks in advance!
