mgwerks
I am having a problem with rear alignment on my NB, Align shop says that it is out of spec and can't be adjusted (true), and that it needs to be replaced. The car has suffered no insult to cause the rear to get tweaked, and the last alignment it was within spec (same shop, same machine).
The question is, could it be bad bushings? if failed, could they be far enough out of shape to cause rear align to go out os spec? I'd rather replace a set of bushings than a whole rear beam. Any suspension geometry experts out there?
Mark
Mark
