Old May 2nd, 2011, 12:26   #1
fastcash43
Default TDI Jetta coolant connector
Hi folks, while I wait for my replacement coolant hoses which blew out from a dripping diesel from a leaky ip I thought I would post a pic and ask a question. I want to make room to approach a stripped injector pump head torx bolt straight on so I don't screw the job up. I need to remove the coolant connector in the circled area. It looks like 2 bolts. Is there anything I should be concerned with here? Does it just bolt right off ? Are there parts I'll need to replace (o-rings, gaskets) if I take this off ? Thanks for any comments / advice you can share.
fastcash43 is offline   Reply With Quote
Old May 2nd, 2011, 12:42   #2
compu_85
Gadget Guy
compu_85's Avatar
Buy a new one before you remove the old one. Also get a new O ring. Yes, it just unbolts from the head.
I'd also suggest working on the IP with it off of the car. Others say you can do the job without too much trouble on the car, but I really like working on it on the bench instead. It's not much more work to pull the pump off the car.
-J
Present:
2018 Tesla Model 3 DM. 3500 miles.
2014 Cadillac ELR. 33,000 miles.
2013 Fiat 500e. 33,000 miles.
99.5 Jetta "GLX" TDI. 323,000 miles. Power Memory Seats, HIDs 11mm pump, BV39 Turbo, RCIII 36/47 MPG.
Past:
2012 Passat SE TDI DSG. 114,000 miles. LED tails, Memory Seat, HIDs. Bought back by VW.
2004 Touareg V10 TDI. 165,000 miles. Sold to Matt98AHU w/ flat camshafts.
Thank you for giving me the BUG*PWR award. It means a lot to me!
Old May 2nd, 2011, 12:46   #3
fastcash43
thanks compu, It's a mater of confidence for me. At some point I'll tackle a timing belt/water pump/proper belt tension, change out, but I'm still learning the basics and don't want to get too far over my head just yet. This is a great site here and I appreciate all the comments/advice you guys take the time to share.
Old May 2nd, 2011, 12:49   #4
compu_85
Gadget Guy
compu_85's Avatar
IMHO there's less chance for error pulling the pump off of the car. Proper belt tension is easy on the TDI, just line up the 2 marks on the tensioner
-J
Present:
Past:
Old May 2nd, 2011, 12:59   #5
fastcash43
thanks compu, keep in mind this is like easing a crazy man off the edge of a cliff here in terms of confidence that I can take that next little step to safety )
Old May 2nd, 2011, 17:58   #6
fastcash43
I removed the flange? and noticed the o-ring is too soft and needs to be replace just as compu suggested. Does anyone know if this o-ring can be matched up at a pepboys or autozone kind of place ? Or is this a special order import type sizing on these ?
Old May 2nd, 2011, 21:32   #7
schultp
schultp's Avatar
I would replace the plastic fitting. Purchase it along with the proper o-ring from one of our trusted vendors. These plastic fittings can be brittle and it is best to replace when you have it off anyway.
Paul.
2010 JSW TDI, 6sp manual
schultp is offline   Reply With Quote
Old May 3rd, 2011, 04:19   #8
fastcash43
Thanks schultp, I'll do that, let me look around this site for a list of vendors, hopefully someone local to my area.
Coolant Glow Plug connector ?? JettaDrvr TDI 101 9 April 11th, 2017 01:00
[WTB] 2001 Golf TDI Coolant Temp Sensor Harness Connector Curtis328 Private TDI Items for Sale/Wanted 3 January 19th, 2011 08:05
how do i remove the connector on the radiator coolant switch bobhammond TDI 101 3 September 17th, 2009 14:05
D'oh! Coolant res connector.... Kyuss TDI 101 2 February 29th, 2008 13:13
Coolant leak at coolant thermostat / hose connector jpmurphy VW MKIV-A4 TDIs (VE and PD) 6 January 14th, 2003 04:26
Page generated in 0.10685 seconds with 11 queries
[Output: 88.19 Kb. compressed to 76.44 Kb. by saving 11.75 Kb. (13.33%)]
