Old January 29th, 2010, 13:11   #1
drrandall1
TDI(s): 09 Jetta TDI
Fuel Economy: 40ish
Default Iphone connecting to 09 Jetta TDI
I think all I need is a auxilary chord right? I connect it inside my arm rest and push cd until it goes to auxilary?
drrandall1 is offline   Reply With Quote
Old January 29th, 2010, 13:28   #2
apaterso
TDI(s): Jetta 2009
Fuel Economy: ~40mpg best to date is 52.3
guess it depends on what you want to do. If you are looking to charge and talk on the phone portion, you are out of luck, won't work. If however you are looking to listen to the iPod part, all systems go.
Plug the cable into the headphone jack, select whatever you want to listen to, turn volume all the way up on the phone. Find AUX on your radio and you should be hearing your iPod.
2009 Jetta TDI manual; build date 07/2008
2012 Honda Pilot
apaterso is offline   Reply With Quote
Old January 29th, 2010, 13:52   #3
drrandall1
Fuel Economy: 40ish
Default Thanks
Cool. Sounds great. Nice to find out it will cost less than $10. Thought I was going to have to get an adapter thing.
Old February 4th, 2010, 14:26   #4
SeePalm23
I have bluetooth vokl system in my 09 and wonder if I get the iPhone I could stream through that to listen to music. Curious to see if anyone knows. Otherwise could just do the cord hook-up.
SeePalm23 is offline   Reply With Quote
Page generated in 0.14350 seconds with 10 queries
[Output: 57.14 Kb. compressed to 50.81 Kb. by saving 6.33 Kb. (11.09%)]
