assaultwagen
I just matched my kerma tune with their DSG tune. This is a definite must! The process was very simple. Much like using the Qpro, you connect the supplied connecter to your transmission data port under your air intake box and download the factory info from the transmission and upload it. The software is sent to you in a link along with easy to fallow instructions. Then simply email it to kerma tuning and in a few hours, or less, you will have your performance tune. Uploading is simple, you can now upload it via the obdII port.
The new tune is great. In D, it keeps your rpm's in peak performance range to help you get better mpg, increases available torque (you can really feel it), and firms up the shifts. The sport mode is a whole different beast. It keeps your rpm's at peak torque and snaps the rpm gauge when you get on it. It also holds rpm's better and decelerates like a dsg should. The shifts are much more firm without feeling too rough while still pushing you back into the seat. It now performs like running in manual mode without the lag or sloppy slow shifts.
