Go Back   TDIClub Forums > VW TDI Discussion Areas > General Automotive
General Automotive General automotive discussion. This is intended to be a discussion about other not VW and Diesel cars you may have or interested in.
Old March 25th, 2020, 03:02   #5506
Mongler98
dont know how i stumbled into this giant mess of a thread but i got my popcorn right here
Old March 25th, 2020, 06:31   #5507
turbobrick240
turbobrick240's Avatar
Originally Posted by where2 View Post
ON-Grid was cheap during the last "great recession". My wife's from "The County". I appreciate the fact that your current governor reversed the previous governor's scrapping of Net Metering. We've got a 4.6kW array destined for our property in Emera territory. When my wife inquired what Emera wanted to know before we install PV, they basically said: Show us a diagram of how it all works. (I did an NEC compliance diagram for my 4.4kW, the 4.6kW is nearly the same diagram, I can probably handle that). It was like a dream come true when they installed fiber optic internet going past our farm for $60/mo. (Wish I had fiber in the suburbs in South Florida!) I pay more for cable internet with slower speeds in FL...
Honestly, that depends on how far you drive each month. I bought an e-Golf because my commute had gotten so short it was murder on the TDI engine. I'm averaging ~500 miles per month in my e-Golf. That would require 4 south facing 280W PV panels. I've got 4.4kW on the roof (installed in 2013), so I have a baseline knowledge of what my 220W panels will produce. Each of my 220W panels collects enough sunshine to drive 3.25 miles per day. (conservatively speaking, when averaged over an entire year!).
Price them again in a few weeks after the dust starts to settle from the current pandemic. My wife and I went with a Low-E (+argon) setup in our hurricane impact windows back in 2010 when the economy was in the dumps, and eager contractors could be easily found. We also insulated and weather sealed "this old house" which helps more than most people think.
Land up here was truly dirt cheap when my folks moved here in '72 from Cambridge. Despite being broke, they begged, borrowed, and begged enough to buy additional properties and did quite well selling them to other young folks moving up north. When the markets are crazy like they are now, I'm reminded of how land is a solid investment. Glad to hear your solar install approval went smoothly! It must be very gratifying to see sunshine fill your "tank".
Old March 25th, 2020, 07:13   #5508
SilverGhost
SilverGhost's Avatar
With the required hurricane impact protection code in Florida I have noticed new builds over a certain price point are dropping "shutters" in favor of impact rated windows.
We already called and talked at length with Tesla on solar and battery wall. Biggest stumbling block is adding another bill after moving several states and furnishing a house. But it has to happen soon, before the tax credits all expire.
Added incentive on the eGolf is neighbor a couple houses down drives one. It has the range to get to work and back each day with "free" charge at work. Having it charge off solar would be a bonus.
That said we have a conventional 2300sq/ft house with a FPL bill $70-$120. Brother inlaw has seen $400-500 bills. So we are already electric scrooges and that makes the payback on solar harder than, say my wife's brother.
Jason
VW and ASE Master Mechanic. Means nothing without the 15+years working at VW. Also know my way around an aircooled 34 pict 3 or Bosch D-jet.
Old March 25th, 2020, 12:35   #5509
tikal
Fuel Economy: 37 MPG (~ 45% city)
Thanks for the suggestion. We did our double pane windows upgrade a few years ago so it is not going to happen anytime soon.
I need to research more regarding if anything worthwhile I can do inside the attic such as putting some material to reflect the heat back into the atmosphere in the summer (May through October for our area).
tikal is offline   Reply With Quote
Old March 26th, 2020, 06:59   #5510
kjclow
one easy solution is an attic fan. Blow the hot air outside instead of letting it sit under the roof. I put one in shortly after we moved down here. I need to replace it before summer as it's burned out after 20+ years.
2010 silver/black JSW TDI with DSG, 2017 Ram 1500 EcoDiesel
Old March 26th, 2020, 11:01   #5511
tikal
Yes thanks. We got it installed a few years ago. It is thermostatically turned on at 90 F attic temperature.
Old March 26th, 2020, 11:28   #5512
truman
I have mine set to turn on at 85
Humidistat also good for high humidity events
truman is offline   Reply With Quote
Old March 27th, 2020, 05:40   #5513
SilverGhost
Couple of neighbors installed twearly birds instead of proper attic fans. I think I may visit this idea after we get the builder in to fix all their eff ups!
Jason
Old March 27th, 2020, 14:56   #5514
JDSwan87
Black Swamp Thing
JDSwan87's Avatar
On a lighter note, though still EV related, I modified my daughter's Mustang Power Wheels to run on 2 20v DeWalt batteries... low voltage isolation circuit board on the left and motor speed controller on the right
Stella (Mine now): 2005 Shadow Blue Jetta Wagon TDI 09A
Mods: RC1. VCDS HEX-CAN USB (near Toledo, OH)
JDSwan87 is offline   Reply With Quote
Old March 28th, 2020, 06:21   #5515
SilverGhost
OOOO!! Details, please! I've been looking at modifying my daughter's JD Gator power wheels. She wants us to sit in the bed or cram into the seat and drive her around, but the OE battery is not having it.
Jason
Old March 28th, 2020, 07:38   #5516
turbobrick240
Nice, I bet that thing rips @ 20V input . Fast swapping battery capability is pretty neat too. I'm surprised Powerwheels hasn't done something like that already.
Old March 28th, 2020, 07:54   #5517
JDSwan87
Black Swamp Thing
JDSwan87's Avatar
Jason
I can't take full credit. Here's where I got the idea and used the same parts. He links the parts in the description, the low voltage shutoff is in part 2 (separate video by him).
https://m.youtube.com/watch?v=XcVdPOUly6Y
Old March 28th, 2020, 08:00   #5518
JDSwan87
Black Swamp Thing
JDSwan87's Avatar
Total input is 20v 10ah. I've had it set to about 75% and she's got about 20min of run time so far and the batteries are only at 18.6v currently. I have the shutoff set at 16v, so I don't kill the batteries. Oh, and all driving is in soggy grass, minimal gravel, no paved surfaces.
I've cranked it up to 20v a few times for her and it's pretty darn quick to say the least.
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
GM, Nissan and Tesla Premier New Electric Vehicles in Detroit MarcusW General Automotive 1 January 17th, 2013 11:24
How many states exempt diesel vehicles for emissions? Angus Scrimm TDI (Diesel) Emissions 26 January 10th, 2011 21:25
Plug-in or Full-Electric Vehicles? bad idea TornadoRed General Automotive 63 January 16th, 2010 16:46
Extending range in Battery Electric Vehicles (BEV) nicklockard General Automotive 1 March 6th, 2005 13:39
GM pulling the plug on electric vehicles BHarrison TDI News/Tech 4 May 7th, 2003 11:20
Page generated in 0.17620 seconds with 12 queries
[Output: 123.52 Kb. compressed to 104.87 Kb. by saving 18.65 Kb. (15.10%)]
