2003 jetta 1.9 TDI ALH
Looking for trouble shooting for this problem
  • Charts
    Votes: 0 0.0%
  • Thec tips
    Votes: 2 100.0%
  • Total voters
    2
basskleff
MA
2003 New Beetle GLS
I ran into a very similar problem. and it was the O-rings on the T.
Definitely would try replacing them.
alphaseinor
TDI Innovator, Gone but Not Forgotten
Denton, TX
'03 Jetta TDI 780,000 miles (totaled out), 01 Audi TT 225 Quattro 230,000 Miles (runs great!), 00 Cabreetle Beetle dash, ALH & MK4 harness Swap
Air leak... could be any seal in the system.
Rochester NY
Repair shop Work on many
Hard Start 2003 tdi on
Thanks for help replace orings in tee and all the air bubles went away but when coolant temp is below 60 degrees and above 45 the car will not start Cold start in moring perfect and hot restart perfect if it only cools down a little bit once you get to 60 or below it will not start
Car already has new glow plugs and module thermostat and coolant switch only thing when car won't start the glow plugs will not fire not even for the couple of seconds the light is on. Thank you for any help or more information.
alphaseinor
Denton, TX
Eastsideservice said:
Check Timing belt marks & injector pump line up perfect
uhh... there's one problem here... there are no marks on a TDI engine!
