paramedick
TDIClub Enthusiast, Vendor
Help!!! Jetta dead in driveway. All dash lights come on, and I hear a click when I turn key.
I have done the following since starting it last.
1) Disconnected one glowplug lead to check size of glowplug. Reconnected lead.
2) Dropped down fuse panel to see where the headlight/lights on chime goes. Did not insert chime due to no shop manual at this time. Disconnected nothing.
3) cleared a CEL for intermittent glowplug problem with unregistered VAG-COM (just had hard drive changed in laptop, waiting for registration # from Ross-Tech)
4) Checked the wiring on the back of the European light switch to make sure all were connected.
I have done the following to see if I could get it to start.
1) ensured that the new battery was indeed charged.
2) jumpered the clutch interlock switch without effect.
3) looked again at the fuse panel. There are no disconnected wires that I can find.
I am still learning this car. Lost my Bentley with hard drive crash, so no manual.
Any suggestions greatly appreciated.
