witchcraftz
Here's how I fixed it:
I used a 3/8th NPT ot NPT connector , a 3/8 to 1/2 " hose barb adapter to fit into the 1/2 inch hole, a nut to fit on it, a pin from a trailer, and a metal strip about 1.2 inches wide and 5 inches long.
I sanded the interior of the connector so it was nice and smooth because mine had a rough edge on the inside.
Then I made a 3/8 inch hole in the metal strip big enough to thread the connector.
Here is what it looks like.
Bend the two ends of the metal strip.
There return tee is inserted into the NPT to NPT connector
The pin is used to secure the return tee. I made a few holes just flush with the return Tee and put the pin through them.
