Go Back   TDIClub Forums > VW TDI Discussion Areas > General VW Discussion
General VW Discussion This is a place for General VW topics (the company, not your vehicle). General topics about a specific vehicle should be posted in the General TDI Dicussion Forum sections for that vehicle platform. A4, A3 & B4, B5, etc.
Old September 23rd, 2018, 18:34   #1
crustodd
Default Panaramic roof reliability/ issues?
Hello All TDI-ndividuals,
I'm finally about to move forward on a TDI Jetta Sportwagen purchase. I'm really looking fo a solid roof model, but am facing the possibility that may not be available when I'm seriously ready to purchase. If I had to buy one with the Pano roof, I wouldn't likely use it much. I'm in the PNW and the weather isn't roasting here very often. So, what issues are there with the Pano roofs? Do they need maintenance? Mostly anxious about possible breaking the glass or electronical issues.
Thanks for all input
crustodd is online now   Reply With Quote
Old September 23rd, 2018, 19:49   #2
JSWTDI09
JSWTDI09's Avatar
I have heard very little about breaking glass or electronic problems with the pano roof. Most of the problems reported are leaks caused by damaged rubber seals and drain line problems which both cause water problems. The sun screen has also caused problems for some. Both the sunscreen and the window itself have also been known to get out of their tracks. This often requires removing the entire headliner and replacing the entire frame (read: expensive).
My old '09 JSW had a pano roof and I live in the desert. I hated the "green house" effect. My roof never caused any problems (except for heat) but I rarely opened it. My current car has no pano roof (on purpose!).
Have Fun!
Don
2009 Jetta SportWagen TDI (gone but not forgotten)
2018 VW Tiguan SE (I wish it was a TDI)
JSWTDI09 is online now   Reply With Quote
Old September 24th, 2018, 03:54   #3
oilhammer's Avatar
Fuel Economy: fantastic
Greenhouse effect is bad, the sunshade isn't enough.
They can creak and pop on uneven roads when cold.
I have had a few that did random strange things like open on their own for no good reason.
If drains are not kept clean, they can cause leaks (regular sunroofs can too).
I understand not being able to find one without, they seem to be pretty rare. We had a fleet that had a whole bunch of them (all automatics of course). But beyond those, I would say more have them than do not.
www.cardocautomotive.com
Old September 27th, 2018, 18:04   #4
crustodd
Thanks for the input, peeps. As much as I klike the occasional air and the extra light, the risks outweigh the benefits. There are enough steel roofs around for me to lean that way :-)
Old September 27th, 2018, 19:12   #5
w123houston
the audi allroad my jetta replaced had the pano roof. needless to say, my jetta has a steel roof
w123houston is offline   Reply With Quote
Old September 28th, 2018, 07:42   #6
JSWTDI09
JSWTDI09's Avatar
My '09 JSW had the pano roof. I now drive a Tiguan SE. The primary reason why I bought the SE version is because it is available WITHOUT the pano roof. All higher trim levels always have the pano roof as standard equipment.
Because of my experience with pano roofs, I now also have a steel roof.
Have Fun!
Don
Old September 28th, 2018, 20:37   #7
Ol'Rattler
Ol'Rattler's Avatar
Not being able to find a Dub without Pano would cause me to shop a different brand. A Pano roof and factory Navi are probably 2 of the most ridiculous options that manufacturers inflict on people.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Jetta 2009 reliability issues Tcooper317 TDI 101 5 January 11th, 2014 08:05
R783 reliability issues? numbnuts TDI Power Enhancements 7 April 26th, 2010 11:47
PD cam issues / reliability Jarmstrong VW MKIV-A4 TDIs (VE and PD) 13 July 18th, 2008 02:41
Reliability Issues sjd VW MKIV-A4 TDIs (VE and PD) 13 June 15th, 2004 19:13
TDI reliability issues??? whats up?? glos TDI 101 26 July 11th, 2003 14:43
Page generated in 0.15596 seconds with 13 queries
[Output: 82.11 Kb. compressed to 71.37 Kb. by saving 10.75 Kb. (13.09%)]
