Go Back   TDIClub Forums > VW TDI Discussion Areas > OBD Scanners
OBD Scanners Discussions on using On Board Diagnostic (OBD) scanners/ Diagnostic Equipment related to TDIs
Old June 28th, 2018, 19:13   #76
550TDI
Originally Posted by dandan81 View Post
I did notice that our engine wasn't on the supported list yet.
Shame the scan in Torque Pro doesn't quite work...
Sent from my SM-G950F using Tapatalk
I have been in contact with app builder and did couple of test with him.
You can use engine group 10 if you want.
Group 7 also work but the working fields are little bit different .
He may eventually group all working fields in one group.
Sent from my SM-G965F using Tapatalk
550TDI is offline   Reply With Quote
Old July 30th, 2018, 18:33   #77
550TDI
Maybe we are looking on wrong PID or section... all my DPF are in SAE 8. Not to sure how this works.
Sent from my iPad using Tapatalk
Old July 31st, 2018, 15:49   #78
550TDI
Today I successfully access DPF % with torque
Pid 018b
(C*100)/255
When it reach 100% regeneration will start.
Also if someone can make sense of other infos here and create useful equations.
I would love to have the one who tell you when DPF burn is actually on.
Thanks.
Old July 31st, 2018, 19:50   #79
550TDI
Pid 018b
(C*100)/255
Thanks.
Ok I did it today
Pid 018b
Équation {B:0}
Got 2 return values.
0 = passive regen
1 = active regen
Old August 2nd, 2018, 16:30   #80
dandan81
That's awesome, I just found the 018b PID too and am trying to understand the same thing.
This will help alot, I'll let you know what I find.
dandan81 is offline   Reply With Quote
Old August 2nd, 2018, 17:00   #81
550TDI
Getting there slowly.
Water Level Sensor False Reading vwfern VW MKIV-A4 TDIs (VE and PD) 6 November 24th, 2013 21:10
Can Vag-Com adjust fuel level reading? shizzler OBD Scanners 3 August 4th, 2010 12:44
Messing with the Air Flow Meter Reading for tuning and to help combat soot? Possible? pietch TDI Power Enhancements 2 September 14th, 2008 03:57
Fuel Gauge isnt reading correct level cfm56 VW MKIV-A4 TDIs (VE and PD) 6 June 20th, 2007 05:26
SOOT LOADING LEVEL IN TDI OIL SkyPup Fuels & Lubricants 27 November 24th, 1999 11:19
Page generated in 0.12579 seconds with 12 queries
[Output: 76.61 Kb. compressed to 67.63 Kb. by saving 8.98 Kb. (11.72%)]
