Difficulty starting and/or running in Minneapolis
We've had a cold snap here for the last week, and I have had 3 problems. I too am seeing bubbles in the clear, (return?) line, and at the point when it has died and won't restart that clear line is empty. I got some starting fluid, and sprayed it into the flexible intake immediately after the MAF sensor, and this would get the motor running for 4-5 seconds. This was good because it apparently worked the fuel pump hard enough to get buttery fuel where it needed to go. Keep in mind that it took several iterations of spraying fluid and then re-attaching the hose before it would idle. After it starts, at least initially, the hose gets completely filled, but it's cloudy. REMEMBER, when the engine begins to run with the ether, it will probably rev up uncomfortably high, and THERE'S NOTHING YOU CAN DO ABOUT IT! You basically have a runaway engine at that point, (we have *compression* ignition engines). However this morning when the motor shut down 1 mile from home, I was able to watch the rev counter while it ran away, and it got to 5,ooo rpm, which was acceptable to me because the crankcase oil had a chance to warm up over the last mile, and presumably there was oil in the filter, so oil pressure was up enough to protect parts. When using the fluid, spray for 1-3 seconds, and no longer.
So, assuming that my problems are caused by gelling and not an air leak, it's happening either because there's enough residual biodiesel in my fuel that it has effectively raised the gel point to above 10 degrees F., or my CAT 2 micron fuel filter is too fine for cold, but not solid, fuel to flow through. OR, it's a combo of both.
FYI, I was running 50% biodiesel in the tank before this. My estimate is on a percentage basis, there was about 10% biodiesel in my fuel when I had my first clog, and the temp was maybe 4 degrees F.
John
Minneapolis
