Magellan01
- Joined
- Dec 19, 2001
- Location
- Detroit, MI
At speeds over 50mph there is a wobble in the steering wheel and a noise like the tires are out of round. After investigating the problem I think the front wheel bearings are bad. There is not a squealing noise like I have had with other bad bearings on my car which makes me doubt this. After taking the front tires off there is play in the hub. When I pull on the rotor or hub it wobbles. The steering knuckle is stationary which leads me to believe that there is something wrong with the bearing. Does this make sense to anyone? Tie rod ends seem find and so does the ball joint since they were not moving while I was moving the hub.
