tadawson
Drove the Nissan once - meh, just another generic $**tbox . . . No intetest in the Chebby (re)Volt . . . or any other GM turd for that matter, although they do rank negligibly above Ferd in my book . . .
The Volt should cover that distance (20-30 total?), except maybe if the temps drop below the mid-20's. Even then, a pint of gasoline a day at worst.The Volt will get me in the HOV lane in Virginia, and the electric range will almost cover my entire commute (short about 10-15 miles). My uncle has a volt, so I got some up-close experience with it. That and his own experience has been very positive.
High torque: yep, one of the reasons I drive a dieselIf high torque, negligible range, and long repower times floats your boat, enjoy. For me, it's two things I won't tolerate coupled with one that I am indifferent to . . .
In parts of the US like the west which is so spread out you can run out of range easily on anything offered today. A trip to airport & back in Denver metro area would run out of charge on the way back home for most here.High torque: yep, one of the reasons I drive a diesel
Long repower times: well, depends on your situation and how close a supercharger station is. Yes, takes longer than pumping liquid fuel into the tank. But with adequate range, you're only "refueling" at home overnight.
Negligible range: uh, no. Every other electric out there, yeah, you aren't going to get much more that 75 miles on a charge. But the Tesla, closer to 300. Unless I'm traveling somewhere, I rarely hit 50 miles a day. Maybe 75 on a weekend, again unless I'm going somewhere I don't normally. I could easily live with a Tesla Model S for 90+% of my driving.
You could keep that wagon going indefinitely if you keep after the maintenance. I have seen first hand VW's come close 1,000,000 miles with little other than regular maintenance needed. Shocks, t-belts, maybe paint and keep on driving it....I'm actually pricing Chevy Volts right now as a possible replacement for my '03 Jetta Wagon TDI. The wagon has been great for me and I've loved it, but it will eventually need replacement. It might be a few more years, but it's good to have something in mind and not be caught unprepared. All the diesel options available to me now are unfavorable, as NOTHING can run B100 anymore. Diesel fuel is about $1/gal more expensive here than gas.
My other thought is to replace our family minivan with the Volt, as my wife's around-town driving would also be completely covered with the electric range, and nowadays she rarely needs all the minivan space. We'd probably keep the van, as a backup, for Costco shopping trips, and out-of-town trips.
What drew me to TDIs in the first place in 2003 were two things: Rated MPG (40/city and 50/highway) and B100 compatibility. It's a tragedy that we've actually REGRESSED in both of those areas in the following 12 years, instead of improving. That depresses me, and VW will lose my business because of it.
I'm pretty sure it's illegal for me to do what you're suggesting to make a modern car B100 compatible. Keeping the wagon is something I'd like to do, if economically feasible. Hence my other idea of replacing the minivan instead.You could keep that wagon going indefinitely if you keep after the maintenance. I have seen first hand VW's come close 1,000,000 miles with little other than regular maintenance needed. Shocks, t-belts, maybe paint and keep on driving it....
Or one the currently offered CRs can run on BD if you reprogram and remove or gut all of useless exhaust crap. So there are still options out there. I am sure your BD use has long ago de-activated the emissions stuff on your wagon.
So, like your aging baby they will take a little care and modification to accomplish what you say you want is all that is needed to go with a current car or to keep your old baby running a while longer...........
Emissions disabled? Please explain. Either way, there was no tampering with the actual equipment on my vehicle. VW would classify it "mis-fueling".Your current wagon with it's emissions disabled from years of BD use is no different legally speaking than suggested.....
Also the CR's emissions with or without the emissions crap would be less polluting than your current car under any circumstances.....
That was all I was pointing out. In no way was I suggesting anyone remove anything!
Just the pointing out the facts of what is going on right now..........
Your current wagon with it's emissions disabled from years of BD use is no different legally speaking than suggested.....I'm pretty sure it's illegal for me to do what you're suggesting to make a modern car B100 compatible. Keeping the wagon is something I'd like to do, if economically feasible. Hence my other idea of replacing the minivan instead.
Don't let your actual experience get in the way of rotarykid's ideologyAnd yet my car continued to pass emissions inspections in Maryland....
According to what I have found, your state (MD) has no testing on diesels! So what kind of emissions test are you speaking of?And yet my car continued to pass emissions inspections in Maryland....
Any of these plug in tests can easily be subverted by programming, IE a tune which fools the ECU into thinking all is good ignoring sensor data that is outside of spec's.....Nine States That Require Diesel Emissions Tests
Law Of The Land
Text By Mike McGlothlin
Diesel Power, June 01, 2010
5
In light of California's new diesel emissions laws, which went into effect January 1, 2010, we took a closer look at the country as a whole to find out exactly which states are testing light-duty diesel vehicles with gross vehicle weight ratings (GVWR) up to 14,000 pounds. What we discovered was that every state conducting tests on diesel pickups is only doing so in select counties, or highly populated areas (except Connecticut, which tests statewide). We agree with this practice because in densely populated areas there are bound to be more commuters, and ultimately more pollution. Here is a list of all states currently conducting diesel emissions testing.
Diesel Power Diesel Emissions Testing States Conecticut State
Connecticut
Counties: All
Vehicles Tested: All model years more than four years old with a 10,000-pound GVWR or less
Test Type(s): Smoke opacity (snap-idle procedure with no load on engine)
Diesel Power Diesel Emissions Testing States Colorado State
Colorado
Counties: Adams, Arapahoe, Boulder, Broomfield, Denver, Douglas, and Jefferson
Vehicles Tested: All model years with a 14,000-pound GVWR or less (new vehicles are exempt for first four years)
Test Type(s): Visual inspection for emissions-equipment tampering, onboard diagnostics (OBD-II) check (if applicable), and a smoke opacity test
Diesel Power Diesel Emissions Testing States Arizona State
Arizona
County: Maricopa
Vehicles Tested: Any model year with an 8,501-pound GVWR or greater
Test Type(s): Smoke opacity (the vehicle makes three wide-open-throttle, non-loaded runs with the transmission in neutral)
Diesel Power Diesel Emissions Testing States California State
California
Counties: 40 of 58 (high population areas)
Vehicles Tested: '98-and-newer with a 14,000-pound GVWR or less
Test Type(s): Visual inspection for emissions-equipment tampering, onboard diagnostics (OBD-II) check, smoke opacity test (snap-idle procedure with no load on engine)
Diesel Power Diesel Emissions Testing States New York State
New York
Counties: Nassau, Rockland, Suffolk, and Westchester (New York City metropolitan area)
Vehicles Tested: All model years with more than an 8,501-pound GVWR
Diesel Power Diesel Emissions Testing States Nevada State
Nevada
Counties: Clark and Washoe
Test Type(s): Visual inspection for emissions-equipment tampering, and a smoke opacity test using a dyno to create a load
Diesel Power Diesel Emissions Testing States Utah State
Utah
Counties: Davis, Salt Lake, Utah, and Weber
Diesel Power Diesel Emissions Testing States Wisconsin State
Wisconsin
Counties: Kenosha, Milwaukee, Ozaukee, Racine, Sheboygan, Washington, and Waukesha
Vehicles Tested: '07-and-newer models between 8,501 pounds and 14,000 pounds GVWR (dedicated farm vehicles are exempt)
Test Type(s): Onboard diagnostics (OBD-II) check
Diesel Power Diesel Emissions Testing States Tennessee State
Tennessee
Counties: Davidson, Hamilton, Rutherford, Sumner, Williamson, and Wilson
Vehicles Tested: All model years with a 10,500-pound GVWR or less
Test Type(s): Smoke opacity, and onboard diagnostics (OBD-II) check (if applicable)
As per a post below:
Washington state does a OBD II plug in test looking for codes on diesels in some areas of Washington state (generally the Seattle-Tacoma-Everett area), along with gas engines. However, all diesels 2009 and newer do not require testing because they were certified under T2B5 regulations. So my Passat and Jetta don't require an emissions test, but my Ram 1500 and the daughter's Routan do.
I will state the they no longer actually sniff the exhaust any more. They now plug into the ODBII jack and read for codes. I guess the assumption is that if there's no code, it is compliant. I think it's just another way to get $14 from me.
n1das said:Having driven a 2015 Tesla Model S P85, I attest to the Weapons-grade TORQUE instantly available off the line and at any speed. It is an amazing car. A friend of mine has a 2014 Model S P85 and has ordered the new dual-motor P85D with "insane mode" McLaren F1 type performance. I'll get to check it out after he gets it.
Tesla makes amazing cars however I'll stick with my diesels. Diesel is far from dead IMHO.
I'm sticking with DIESEL, no matter what. Diesel is far from dead IMHO.tadawson said:If high torque, negligible range, and long repower times floats your boat, enjoy. For me, it's two things I won't tolerate coupled with one that I am indifferent to . . .
That will only apply to 2009+ TDIs. The context of those statements were for a 2003 ALH TDI.Exactly - all I have ever heard of is possible oil dilution due to bio evaporating at a higher temp, and maybe faster DPF ash loading (but not certain on that . . .).
- Tim
rotarykid is asserting that it disables the CAT of the older models.Doesn't the 2003 run B100 fine? I was commenting on the statement that they no longer do, which definitely was nkt talking about a 2003 . . .
- Tim
I am not a environmental scientist and I did not stay at a holiday in express last night, but here is what I remember...........That will only apply to 2009+ TDIs. The context of those statements were for a 2003 ALH TDI.
We're not going to "run out", per se, but it will become more scarce and more expensive, so better to have alternatives ready, especially when it's not hard to do. We're just too lazy or unwilling.Aside from fuel and lubricating oils fossil fuels are used to produce plastics, synthetic fabrics, and many other products that we've come to need.
