BoostedOne
Posting here because the car is now modded, but not sure that's really affecting anything.
Mods:
DLC1019's. Egr delete. K03 hybrid. Large front mount. Filter on a stick. 2.5" exhaust. Kerma tune for all of that.
Other relevant work done at the same time:
Timing belt. Excessive intake manifold and intake port cleaning. Engine has 135k according to odometer.
Ok. So before the work, the car ran ok. I was amazed it ran as well as it did considering all of the buildup in the intake and ports.
I did the timing belt by locking the pump with the pin, and releasing the can from the sprocket like you are supposed to. Nothing fought me on the job.
Started the car, ran ok even before I put the tune in. So I get the car warmed up, and go to set the pump timing.
Ok, for one the last few times I did this(different cars) once you switch to basic settings it runs kind of rough.. this thing barely runs. Chugs, backfires, etc. So question 1, not sure if this is normal on big injectors or maybe I just don't recall the last times as well as I think?
Moving on.. coolant temp at 85 degrees, vag com tells me "pump too far advanced to plot". So I shut down, removed all the intake piping so I can get the cover off and loosen the bolts. While doing that, verify that when the crank is at TDC the timing tool pin still slides easily into the pump bracket. Check, it does. So it's likely reasonable to assume the previous owner had the engine running with this kind of advance as well.
So with all the pump bolts loose except the one you can get to with the engine running, start it back up. Get the pump in range with a pry bar, and it's REALLY coughing and farting while in basic settings. Get out of basic settings and it runs like it seems it should. With the pump timing set, I do the hammer mod. Kerma instructions say 5.8. It was at like 1.5 with those injectors. After it changing every time I tightened the bolts I got it to 5.6 and called it good.
Shut the car off, go eat lunch. Come back, tighten all the pump bolts, remove the ic piping so I can reinstall the timing cover, reinstall piping, figure ok now I will install the chips.(this is a swap car, wanted to start it on stock program to isolate swap issues with chip issues).
Go to start the car. Just cranks and cranks and cranks. ECT now down to like 35 deg C.
Ok. Wth. Bad chips from Kerma? Pull the ecu, put stock chips back in. Same thing. You can probably crank it all day and it won't start.
So off comes the cooler piping and timing covers again. Also removed the valve cover to verify cam timing. Everything is good.
Long story short, the only way this thing wants to cold start(cold being 85-90 degrees out) is if the injection pump gets advanced back to it's as found location. That's easy to approximate, because retarding the pump enough to make vag com happy has me fighting the injector lines so hard I can't do it without a pry bar because it wants to spring back so bad.
So I guess what I am trying to figure out is what could be causing this? I have the pump somewhere inbetween right now. Still too far advanced to plot but not near as advanced as when I got the car. Cold cranking it, it takes about 7 seconds to fire, and another 5 to 6 to fire off fully and run. Then it seems fine. Runs strong.
At this point i think I ruled out pretty much anything I could have done wrong? Is it possible the previous owner was having a cold start issue due to some other issue and someone advanced the pump to make it run? Or somehow the pump found it's way this far advanced and did something to the engine where now it needs that much advance to run?
Or could i be missing something?
Oh yeah. No codes except for egr solenoid not present since I deleted the solenoid
Sent from my SM-G610F using Tapatalk
Mods:
