PDJetta
- Joined
- Nov 6, 2003
- Location
- Northern Virginia
- TDI
- '04 Jetta GLS TDI Pumpe Duce Platinum Grey w/ Leather
I was hopping it would never come to this, but from the Virginia DMV web site:
Emissions Inspections
If your vehicle is garaged in the counties of Arlington, Fairfax, Loudoun, Prince William, or Stafford, or the cities of Alexandria, Fairfax, Falls Church, Manassas or Manassas Park, your vehicle must meet the emissions inspection requirements.
Which vehicles require an emissions inspection?
The following vehicles require a Virginia Emissions Inspection PASS or WAIVER before DMV can complete the registration process. The requirements are categorized by fuel type [I omitted the stuff about gasoline cars]:
1997 and newer diesel vehicles with a manufacturer’s designated gross vehicle weight of 8,500 pounds or less will receive the on-board diagnostic computer system test. Diesel vehicles will not receive the tailpipe test, fuel cap pressure test, visual component inspection, or the visible smoke inspection.
You can not renew the vehicle's registration unless the emissions test is passed. The emissions test is required every two years.
--Nate
- Diesel-powered passenger or property carrying vehicles with a model year of 1997 or newer and with a manufacturer’s designated gross vehicle weight of 8,500 pounds or less.
--Nate
