whitedog
At the John Deere Tractor shop, we have a used tractor that when another store took it on trade, they filled a couple of new batteries and threw them in the tractor without charging them. (Most Deere batteries are shipped dry and filled at the store when you buy them.)
The tractor hasn't been cranking over fast enough so I was checking the batteries. First up was the Multi-meter. 12.5 volts or so on each battery, but I never trust a multimeter on a battery. I then load tested the batteries with a 120Amp load tester. This actually showed them to be good, but I was still uncertain since it wasn't much of a load for an 8D battery.
Out with the multimeter again and I checked the voltage between each cell and had right about 2.2 volts each. Well, I wasn't sure about this, so I asked the boss man and he grabbed his specific gravity tester.
I sampled each cell and they were all just above being water. The lowest number on the guage is 1100 with 1200 being the lowest part of "fair" and 1300 being fully charged. My readings were about 1125.
Unfortunately this meant that the salesman was probably right. (of course he knew more of the story than we did, so I'll let him have that one)
So I put the batteries on little trickle chargers at 2 Amps and after half a day they showed no improvement, so I got out the bigger, 10 Amp charger and hooked it up to one battery. This battery started to bubble and give off that rotten egg smell we all know and love.
I checked the SG of the cells about every hour and it slowly came up and up, bit by bit. Tomorrow, I'll start it charging first thing in the AM and see if we can get a full charge on it by the end of the day.
My reason for posting this is because I have read Gurus post that you should check specific gravity, but it never really hit home until this occurred.
The battery passed two voltage tests, and it passed a load test, but it didn't pass the specific gravity test. If you are having slow starting problems and the battery reads 12 volts, that doesn't mean that it is fully charged. Get a specific gravity tester (AKA Hydrometer or refractometer) and check the specific gravity of each cell.
Here is a website that goes into much more detail about batteries and how to test them. I want to include this link since I am far from an expert and it's important to get information from more than one source when reading on the internet.
Here is the first site I went to that has one kind of tester.
Here is one more link, this one to a refractometer.
**Post location disclaimer**
I guess I'll post this here in TDI 101. This post is a bit of general information that applies to all cars, TDIs as well as non-TDIs. VW and Toyota's, Dodges and Deere. I can't find a best place for this post since it is so general, so I'll just post it here in TDI 101. Forgive me if it's wrong.
