NWVintage
Hey everyone-
So I just finished doing the timing belt and installing a pd150 TIP that I got with my 6-speed conversion from RyanP. With my transmission, I got the the OEM Sachs clutch/flywheel for the PD150 that Ryan offers. This flywheel does not have a TDC mark on it. My answer to this was to mark the pulley on the crank. I used proper locks on the cam and IP, and checked everything often during reassembly to make certain that everything was in it's right place. Everything is back together, re-timed and running great.
Simultaneously, I installed a PD150 TIP.
As I said, everything seems to run/work great except that it seems to me as though I may be lacking power when at higher speed. This doesn't make any sense, does it? In lower gear/speed, the PD150 TIP seems to have made quite a difference in higher-rpm boost but once I get to 3rd and 50mph or so, it seems more sluggish than before. The turbo also definitely lags quite a bit more (run 1st gear to 4k or so, shift to 2nd and there is a full second before boost appears to build).
My concern is mostly that my crank may be a couple degrees off from my cam and IP. As I said, I marked the crank pulley during removal of the old belt but that positioning was based upon the assumption that it was correct before. I also did not loosen the IP pulley until I adjusted the timing, so assuming that the old timing belt was not significantly stretched (it didn't seem to be, based upon the position of the old tensioner), the crank and IP would be timed exactly the same in relation to each other as they were before Is there any way to check the absolute crank position without actually dropping the pan and having a look?
Any thoughts would be appreciated.
