Old April 2nd, 2013, 23:02   #1
TDIGLI2002
Default 2002 GLS without steering wheel, will I lose Cruise Control?
I am considering buying this GLI steering wheel.
I will lose my steering controls, but thats fine as I dont have OEM radio anymore and I barely use cruise.
However, I am realizing I do not think I can set cruise without it.
If you need the wheel to cruise, that is rediculous, but I got to guess the set and slow down buttons are just electric signals.
I wonder if I could fabricate those buttons?
TDIGLI2002 is offline   Reply With Quote
Old April 3rd, 2013, 05:43   #2
gforce1108
gforce1108's Avatar
Fuel Economy: Jetta: 44.5 summer / 47 on snows
You might be able to install the headlight dimmer 'stalk' that has the cruise buttons in it. My dimmer failed and the replacement was slightly different. I have the buttons on the wheel and now also have them on the stalk. Not sure why it came that way - 1stvwparts.com (dealer) order....
Regardless, both sets of buttons work. I don't see any reason why your '02 would be different.
I hate rockauto.com http://forums.tdiclub.com/showpost.p...&postcount=236
04 Jetta GLS 5sp - EGR delete, RC3, VNT17/22, 3" turbo back exhaust & 2.5" FMIC+PD150 intake. SBC Stage 2 Endurance w/SMF. Eibach lowering springs
gforce1108 is offline   Reply With Quote
2002 Cruise control did not disengage akasha VW MKIV-A4 TDIs (VE and PD) 4 November 29th, 2012 00:17
Steering wheel controls and Cruise Stoped working! bagdwag TDI 101 11 December 3rd, 2010 21:06
Steering Consol smoking after using cruise control uwaidye VW MKIII-A3/B4 TDIs 4 April 18th, 2010 11:55
Need help: No horn, cruise & volume control on steering xbangu VW MKIV-A4 TDIs (VE and PD) 5 September 17th, 2007 18:09
Could I replace a non steering wheel control car with a steering wheel with controls? dieselsRus VW MKIV-A4 TDIs (VE and PD) 4 April 11th, 2007 06:55
Page generated in 0.12376 seconds with 11 queries
[Output: 53.53 Kb. compressed to 49.41 Kb. by saving 4.12 Kb. (7.70%)]
