Old November 26th, 2012, 13:48   #1
akasha
Exclamation 2002 Cruise control did not disengage
I was driving on the freeway, after exiting I tapped the brake to disengage the cruise control. It did not disengage. The brakes kind of locked up a bit. Scared me. After a moment of panic I was finally able to get the cruise to turn off. My fiance just had the same issue. I am considering getting rid of the car because this issue un-nerves me a bit.
Possibly unrelated, but sometimes when I turn my signal on to change lanes the cruise decels for a second and then returns to normal.
2002 Jetta TDI
128k
Any help would be appreciated.
akasha is offline   Reply With Quote
Old November 28th, 2012, 09:49   #2
akasha
Anyone?
Old November 28th, 2012, 09:55   #3
Rxfire
Rxfire's Avatar
I'm not too familiar with Beetles, but..
If your steering wheel is NOT a Multi Fuction Steering Wheel (MFSW), and is without stereo and cruise on the wheel...
With Cruise control ON, if you tap the brakes to disengage the Cruise, then immediately hit the blinker stalk, it is easy to accidentally hit the "resume" upper lever which re-engages the cruise.
I am not syaing that this is your issue, just has happened to me previously
Otherwise, you may have a blinker stalk or cruise control module issue
2 each 2003 GLS Jetta Wagons (White/tan leather and White/black leather), 5 speeds, Panzer plates, roof rack cross bars (hers), homelinks, 520 nozzles, ventectomies, trailer hitch (mine), VR6 front springs (hers); 1 inch lift kit w/ESP (mine) 1986 Isuzu Trooper Turbo Diesel, 1985 Isuzu P'up NA Diesel
Rxfire is offline   Reply With Quote
Old November 28th, 2012, 13:07   #4
Powder Hound
Powder Hound's Avatar
Your NB has a death wish for you, so you must sell it to me for $1. It is the only way to avoid a horrible firey death.
OK, well if you don't believe that, then maybe you just need to replace the switch(es) on the brake pedal.
If you decide to replace the turn signal stalk, it is pretty easy to do. Just find one from a car being parted out. Make sure it is one that has the toggle switch on the end, not the older push button design. The older one will fit, but the switch gear inside isn't as good as the later toggle switch one.
Old November 29th, 2012, 00:17   #5
Crankous
Crankous's Avatar
Or to me for double the price! hell I'll even triple it 3 bucks!
But really,
I second the motion for a new brake switch and or a new stalk switch set. obviously you could wait for the stalk switch until it gets pesky.... Here is a link to order a new brake switch if you have the late model version.
They are super expensive .
http://www.idparts.com/catalog/produ...roducts_id=572
Crankous is offline   Reply With Quote
Cruise Control Drops, Traction Control Light Flashes Alchemy VW B5 Passat TDIs 10 January 2nd, 2011 21:07
Does 2009 ESC activation disengage the cruise control? dave729 VW MKV-A5 Golf/Jettas 6 November 12th, 2009 09:48
No cruise control, with cruise light on gotdiesel TDI 101 14 July 2nd, 2009 18:57
Clutch doesn't disengage Cruise Control TDImonkey TDI 101 5 September 2nd, 2007 18:15
Wanted: 2002 or newer Jetta cruise control dman268 Private TDI Items for Sale/Wanted 2 November 17th, 2003 11:42
Page generated in 0.13152 seconds with 11 queries
[Output: 69.85 Kb. compressed to 61.94 Kb. by saving 7.91 Kb. (11.32%)]
