Old April 23rd, 2009, 20:27   #1
Bino
Default Cruise Control Retrofit, MKIV Golf
Hey all, I just picked up (well, will be picking up this weekend), a 1999.5 2dr. Golf TDI. The car is not currently equipped with Cruise Control, as per the dealer. I found this link, that outlines the cruise control retrofit. I just wanted to clarify whether or not these instructions are valid for US made vehicles. Everything I've found about Cruise Control retrofits says something specifically about European models.
Much Thanks
Bino is offline   Reply With Quote
Old April 23rd, 2009, 22:23   #2
MOGolf
MOGolf's Avatar
I don't think I've seen a US market MkIV Golf/Jetta/NB without a cruise control. Yes, the instructions do look like they are correct for fitting it, if it truly is missing.
Unchained motoring
MOGolf is offline   Reply With Quote
Old April 24th, 2009, 05:22   #3
Growler
Got Soot Vendor
Growler's Avatar
I remember that the GL newbeetles did not have cruise control in the first couple of years. altho all I remember them having to do was get a cruise control stalk and plug it in.. not the extra wiring shown here.
perhaps its different for the golf/jetta.
~Aaron~
Schmutz 2015 GSW S DSG
Schnurren 2001 Golf 2 door.
Old April 24th, 2009, 09:47   #4
Bino
Yeah, I've read a couple times that all TDI's come with Cruise Control. So perhaps the dealership is just confused... they didn't go out and look at the car when I asked. And it seems odd that it would have A/C but not cruise... given that A/C is a ton of extra components, and the cruise is just a switch on a stalk that has to be there anyway... I'll find out soon enough.
Thanks for the replies.
Old April 24th, 2009, 10:42   #5
jcrews
jcrews's Avatar
TDI(s): All gone
It could have the stalk, but the cruise could be disabled. There are login codes that switch it on and off. About 1 minute with the VCDS and it will work if it's just turned off.
jcrews is offline   Reply With Quote
Old April 24th, 2009, 14:07   #6
NB_TDi
NB_TDi's Avatar
Fuel Economy: Best 56MPG
There is no cruise light on the 99 and 00. If that's what threw 'em off.
Check the stalk yourself. Don't let other people tell you what something is or isn't when buying a car.
1994 Jetta 1.8 2000 Jetta TDI, 2005 Jetta 2.0, 2010 Tiguan 2.0 TFSI 4Motion, 2014 Jetta 2.0
Everytime you post a picture with PhotoBucket, a TDI gets below 30MPG.
NB_TDi is offline   Reply With Quote
Old April 24th, 2009, 18:03   #7
Birdman
Fuel Economy: 55 summer 50 winter
My 01 did not come with the cruise light, I think they started in 02 but not sure. I have am Euro ECU that when I use it the light comes on so the lights are there just not turned on. I don,t like or need another light on anyway,
2003 Jetta 216 injectors, race pipe, OMI, 2.5 cat back pipe, Sachs power clutch,Lightweight fly wheel,Rocketchip 3.0,Dieselgeek race pipe,Borla SS exhaust,Dieselgeek Intercooler pipes,Pierburg MAF,EU cluster with LED Boost gauge,,
Ventectomy,Alientech window,Old Navy ccv filter,Catch can,Dieselgeek short shifter,ATE power slot rotors,Porterfield pads,Shine suspension,Shine rear sway bar,TT pedals & foot rest,Cat fuel filter 2 micron,Alum skid plate,Euro headlights and switch,5 Brake light mod.
Birdman is offline   Reply With Quote
Old April 25th, 2009, 01:22   #8
Bino
I should have clarified... I'm not close enough to actually look at the car. I would know perfectly well if I were sitting in the drivers seat whether or not there was cruise control ...
Page generated in 0.14234 seconds with 10 queries
[Output: 81.82 Kb. compressed to 70.02 Kb. by saving 11.80 Kb. (14.42%)]
