Go Back   TDIClub Forums > VW TDI Discussion Areas > Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc)
Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) Discussions about alternative fuels for use in our TDI's. This includes biodiesel WVO (Waste Vegetable Oil), SVO (Straight Vegetable Oil), BTL (Biomass to Liquid), GTL (Gas to Liquids) etc. Please note the Fuel Disclaimer.
Old July 27th, 2006, 13:00   #1
new2diesel
new2diesel's Avatar
Fuel Economy: 42/40/34 - It's an AUTO Dagnabit
Default Biodiesel Strikes again..
Well, My wife took the wagon into the dealer because of a shimmy in the steering wheel. Obviously either a wheel bearing or a unbalanced tire.. Under CPO it was replaced for free.
Well, when told about the work done, the service manager says that the tech seems to think that it's the Biodiesel that's causing the engine to not run right, causing the wheel bearing to go out. (BTW we do have a BioD sticker on it.) Because this is the second wheel bearing to go out inside of 3 months. Previously it was also the ABS sensor ring that was the problem.
We do use BioD, but only what's available locally, no homebrew.
Can anyone shed some light on this?
Only car in the stable: 02 Jetta GLS; AT, Blue, Ventectomy, RCII, PVC Boost Gage pod, Remote Window Mod. (Thanks onehotspud!)
RIP:02 Jetta Wagon GLS - Baltic Green Pearl; Lost in pinball accident of '09.
RIP:'05 Passat GLS - Stonehenge Gray; Lost in the vehicle trade-in of '13
new2diesel is offline   Reply With Quote
Old July 27th, 2006, 13:20   #2
Kayakkermit
Fuel Economy: 5.6L / 100 km
This is new, fuel causing bearing failure.
It caused the Black Plauge, Anthrax and Ebola too.
What a bunch of bunk.
Sounds an awful lot like this dealer is trying his best to do his worst.
FWIW, been in the bearing business for over 17 years.
I can call myself a pickle all day long, it doesn't make me one
Giles L
Kayakkermit is offline   Reply With Quote
Old July 27th, 2006, 13:56   #3
mahana79
TDI(s): 2002 Jetta
You have got to be kidding me!!!!!!!!!!!!!!!!!!! BioD is causing bad bearings now Guess i better be stocking up on those too
2005 Chevy Crew Cab Dually Duramax/Allison
2002 VW Jetta TDI-----plain jane commuter for now
2004 Kubota L3400
All Stock.........All on 100% Homebrew BioD Well atleast as much as I can make.
"If you're reading this, thank a teacher. If you're reading this in English, thank a soldier!" Unknown
mahana79 is offline   Reply With Quote
Old July 27th, 2006, 15:41   #4
scurvy
Good Ol' Boy
scurvy's Avatar
TDI(s): 2006 Golf
Fuel Economy: ☠☭
Well, when told about the work done, the service manager says that the tech seems to think that it's the Biodiesel that's causing the engine to not run right, causing the wheel bearing to go out...
Sure thing. My opinion of the situation is they are stone cold lying to you in an effort to remove more money from your wallet.
Biodiesel causing wheel bearings to go out? AHAHAHHAHAHHAHOEHAEEHAH
If you put a Christian/Darwin/Bass Pro Shop sticker on your car, would they tell you the tech seems to think it's the fish that's causing the engine to not run right or bearing to go bad?
On another note, how did they know you had biodiesel in the car (assuming you did at the time)? If a stealership started sampling fuel before working on the wheel bearings, they're trying to find ways to weasel out of their obligations.
Run far away from this place.
I could see if you were using biodiesel to clean your wheel bearings that it could wash out the grease and eventually cause bearing problems, but I assume you haven't been using it to do that (or fill your crankcase, as a dessert topping or as a cavity preventive dentifrice).
scurvy
If you post a question, post your solution!
mk4 front wheel bearing | scurvy winter front | VCDS in Chicago, IL USA
You are entitled to your opinions but not your own facts.
scurvy is offline   Reply With Quote
Old July 27th, 2006, 15:47   #5
torifile
You should just laugh in their faces. That's so absurd.
torifile is offline   Reply With Quote
Old July 27th, 2006, 15:55   #6
new2diesel
new2diesel's Avatar
We both have the BioD sticker/window cling on our cars.
I don't know if he sampled it or not. He must not have read the news that VW warranties upto B5.
I can see that a really rough running engine might cause the cv or universal joints to go because of the backlash, but a Bearing?
My cars actually run a little smoother with the Bio. And it's commercially available less than 5 miles from the house so.??
I'll keep going there as long as they keep fixing it under warranty.. When that's gone.. "Uncle" Marty aka JETaah here I come..
Old July 27th, 2006, 15:55   #7
MikeS_18
MikeS_18's Avatar
ab·surd (b-sūrd, -zūrd)adj.
1.
Ridiculously incongruous or unreasonable. See Synonyms at foolish.
2.
Of, relating to, or manifesting the view that there is no order or value in human life or in the universe.
3.
Of or relating to absurdism or the absurd.
This relates to #3 relating to absurdism and the absurd
'03 Wagon, 5spd,17/22 turbo, RC3+, PP520s, Stage 1 clutch, Old Man Intake, Lift Pump, TT Short Shifter, EGR Cooler Deleted, 800 Mile/tank club
2013 Passat SE and a '64 Ford Econoline Travel Wagon, 200ci straight six, 3 spd, 17mpgs "If it's got a hood, it ain't no good!"
6 Garages?! It's still not enough!
MikeS_18 is offline   Reply With Quote
Old July 27th, 2006, 16:20   #8
naturist
Next thing he'll try to tell you is that the fumes from the biodiesel are what causes static on your radio. I ain't buyin' it.
You might try asking him just what about your appearance made him believe you were that stupid.
naturist is offline   Reply With Quote
Old July 27th, 2006, 17:24   #9
vwrobert51
Fuel Economy: 49- 51 mpg #2 diesel
HEY! let the dealer replace wheel bearing and have it written on repair order that biodiesel was cauise of bearing failure ,and then file a lawsuit!!!! THIS WOULD NEVER BEEN A ISSUE IN MY SHOP! its just to stupid, yeh maybe if you had a fuel system problem with bio fuel but a wheel bearing ,I DONT THINK SO!!!!!!
2004 TDI P/D Jetta Wagon Auto Wheat beige.
1988 Vanagon 1974 beetle (restored)
vwrobert51 is offline   Reply With Quote
Old July 27th, 2006, 17:39   #10
HotRod
HotRod's Avatar
TDI(s): 2003 Jetta
Geez....just when I thought I'd heard every lame ass criticism of BioD.
'97 Passat 146k - sold
'02 Jetta 117k, RC2, Bosch .205's, OMI, B100 year round in sunny SoCal - sold
'03 Jetta 198k, Alligator tune, R520's & SouthBend Clutch
HotRod is offline   Reply With Quote
Old July 27th, 2006, 17:53   #11
Galactic_Warrior
TDI(s): 02 Jetta
Fuel Economy: 54/52/47
Betten or Gezon?
2002 Jetta GLS 5 Speed
DG SS, Oilguard, Wett, E-Codes, was Spec Stage 1, now VR6/G60!
Galactic_Warrior is offline   Reply With Quote
Old July 27th, 2006, 17:55   #12
bhtooefr
ToofTek Inventor
bhtooefr's Avatar
TDI(s): None
Did that dealer hire Audi5000TDI?
Originally Posted by Upton Sinclair
It is difficult to get a man to understand something, when his salary depends upon his not understanding it!
bhtooefr is offline   Reply With Quote
Old July 27th, 2006, 18:06   #13
Gothmolly
TDI(s): 2002 Golf
Well, My wife took the wagon into the dealer because of a shimmy in the steering wheel. ...
Yes, its called "dealer horse****".
!Vent, !DRL, 5 brake light mod, 11mm pump, RC3, Bosio Sprint 520s, VR6/G60 clutch, dead AC, leaking oil cooler, missing belly pan, leaky CCV, leaky valve cover, leaking door seals, broken glovebox, broken horn, rusted fender, dead rear windowwasher, frozen axle bushings
Dead radio? Pull fuse 42, wait 60 seconds.
Gothmolly is offline   Reply With Quote
Old July 27th, 2006, 18:50   #14
40X40
Experienced
Fuel Economy: TBD, new data forthcoming
This post is retracted as further along
the OP reveals the conversation was between
his WIFE and the SERVICE manager, not the
OP and the SERVICE manager.
The service manager was pulling your leg. If you
had laughed he would have laughed with you.
Now I would imagine he thinks one of two things about you.
A. You have no sense of humor.
B. You are clueless.
Or maybe a combination.... Anyway, he offered you a
chance to bond and you missed the boat.
Of course, I could be wrong too!!
You were the only one there, What do you think? Was he serious,
or pulling your leg? Keep in mind, if he was serious it might be that
he did NOT want you to come back, ever. What is your personal history
with the dealership and the service writer? Could he just be trying
to run you off?
Please understand, I am not trying to piss you off! Just offering
another possibility. the dealership may not want to service ANY
cars with bio stickers. They let their competitors be the bad guys
later down the road when claims may be denied.
Bill
www.IHMSA.ORGhttp://www.youtube.com:80/watch?v=Xtsxt7xgbpc
If you omit pertinent info from your question, you cannot reasonably expect a good answer.//Not affiliated with any vendors except as a customer.// Wise people lurk more.// I'm not a guru.// 'I got actual real friends in the real world'-T'sTDI/ If you were the only entry, there wasn't a race.// Grammar and spelling really are important, but I don't claim to be good at it.// Typical drivers can't.
40X40 is offline   Reply With Quote
Old July 27th, 2006, 19:51   #15
Gothmolly
TDI(s): 2002 Golf
My local stealership actually has a pile of "Powered by Biodiesel" bumper stickers on the service counter. Its really a confederacy of dunces.
Page generated in 0.17853 seconds with 10 queries
[Output: 127.59 Kb. compressed to 106.08 Kb. by saving 21.50 Kb. (16.85%)]
