If Im not mistaken, I believe the only significant difference is the VZK has both it's oil supply and drain located on the same side of it's CHRA and the VZ has the more traditional top supply, bottom drain.Hello, I ask you for help. What the difference is in the turbine GTD2060VZ and GTD2060VZK ? I bought GTD2060VZK number 059145873AJ? Is this the same turbine at GTD2060VZ 059145873BB or BC ??
