mcquinn
Replaced my injectors in a working 2002 Jetta ALH engine. Torqued the hold down clamps to 15 FT/LB and seated them with a punch and hammer tap. Started the engine and injector #3 has fuel vapor and pressure shooting vertically. Removed the injector. Checked for tightness and put it back in. Repeated the process. Still visible fuel vapor and pressure shooting vertical. I originally had the injectors professionally set up for 520's, but recently decided to go back to stock 184's. Its an automatic and smoked even at an IQ of 10. Is the fuel vapor a function of the 520's set up? Or are the copper washers not seating? Or is it something else? Any suggestions will be appreciated.
