Gremlin
Hi guys.
I have a 2003 golf. I had been loosing coolant on an irregular basis fo a while. Like for 2 years it would lose 200ml every 4 months, then I had a hose go. That could have contributed. I eventually realized the tank or cap was faulty. I replaced both. Seemed fine then again randomly lost all the coolant in the reservoir. I haven't seen any of the tell tale signs of a blown headgasket but that's where I am thinking this might be going and am taking it in tomorrow to get checked.
I am wondering though, if I'm lucky and it's not the head gasket. Can the ac cause issues. I ask because yesterday I drove 600+kms with the ac on (been brutally hot here in the maritimes) and halfway through the trip I had to pull over, light came on, and fill up the bulb. It was empty. Finished my trip and topped it up this am. Today, I checked the fans and one is not working. So just to see, I drove 300kms back without ac....it was brutal. And no coolant loss. I have looked everywhere and see no leaks. And I am sure it blew out the relief on the bulb as there was coolant all around it. My girl has never overheated, it has 490,000kms on it and o just had the waterpump and timing belt done.
Could the fan not running with the ac on heat it up enough to not overheat but build excessive pressure and relieve it via the build and cap? It is totally random, when it loses coolant. The only common denominator is the ac. New compressor 2 year ago.
Fingers crossed it's not the head, but thoughts anyone???
