pyromancer
Having an issue with my jetta where it will intermittently not start. Been reading through this http://forums.tdiclub.com/showthread.php?t=199398 but not finding the issue.
I have:
*Replaced the fuel filter.
*Replaced the 109 relay.
*Manually ran 12v to the solenoid to confirm it clicks.
*Confirmed the anti shutter valve moves freely and last time it didn't start I tried wedging it open with a stick with no affect.
*I have applied vacuum to the pump return line while plugging the inlet to make sure I had no leaks at the pump or injector lines.
*Applied vacuum at the tank inlet to make sure I could pull fuel. Two pumps with the mighty vac had fuel coming out the line.
I have a new T coming but am not sure mine even leaks, I will give that a test today. Last night it did this again almost stranding my on a trailhead. I had the mightyvac and pulled fuel through the return line, didnt make a difference. What finally got the car started was stepping on the accelerator while cranking it over. Once it is running it seems fine and I am not getting an CEL. I'm scratching my head on what to try next. Any help is much appreciated.
I have:
